TLO
TLO
Canada
youtube.com
2 door
Also, behind the center armrest (for rear passengers) there is a lighting module there as well....not sure if 4 doors had this in previous years?
This should make upgrading older MY Bronco's easier with direct replacement part numbers now...
swamp2
And older Broncos can easily upgrade to get this. Harness from member here, bulbs from Ford and then FORScan.
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
SPV?
TLO
TLO
Canada
youtube.com
2 door
Dunno if you need the harness now? Wasn't it needed for the F150 light modules?
May need @Ducati1098 to run the numbers. It may just be a matter of switching LED's and Forscan.
Strykerwsu
Wichita
Holden Commodores
Does it have a lighted cup holder? Trying to adapt the suggested most similar model I couldnt ever get it to work. So definitely would buy a replacement holder specific to Bronco
TLO
TLO
Canada
youtube.com
2 door
The 2025 has the same screen for ambient lighting. I think it only controls the lights by your feet.
Oh? First I've heard of it for 25's
(Ambient lighting is only in the foot wells AFAIK)
Nope...maybe for 2027 lol
swamp2
@TLO , @Wyld2dr . Not sure what your comments mean. I, among others here added these lights to our rigs with the things I listed.
Rivers90
Ben
Southern California
2 Door Base Sasquatch
I have a 25 and right now I have them set for Orange. I wish it would do more lights as everything else is still the blue color. And I think the orange only comes on after you get in, When you first open the doors it is blue-white color. The 25 got the full digital dash and the 12" screen standard, Ambient lighting was part of all those changes.
Wyld2dr
You didn't say who to get the harnesses from. I was asking if it was SPV.
TLO
TLO
Canada
youtube.com
2 door
Yes, but I doubt you need a home made harness and light modules from an F150.
Should be able to do this straight from the Bronco parts diagram (except custom cupholder) 🤷🏻
swamp2
swamp2
Bulbs are used in many different rigs. I didn't say F150...
Harnesses are unlikely to be available from Ford since the lengths needed are to install in a vehicle wired for front but not rear lights. The harness I procured, as noted above was very OEM in appearance/quality.
TheAaronPerry
Aaron
Sarasota, FL
2022 Badlands
I just did this upgrade on my 2022 and it rocks! Front and rear seat lights. Ordered some lights, the harness from John (linked above) and a little tweak to FORSCan and was good to go
