2025 Bronco Refresh design??
Gregus73
Greg
Los Gatos, CA
2024 Silverado 2500 HC, 2023 Bronco Heritage, WRX
agreed, GMC and Chevy basically the same thing, save a couple cosmetic changes. Just like Ford and Mercury were and why Ford shit canned Mercury.
I always think of the Silverado High Country being the tuxedo clad cowboy vs the GMC Denali being the tuxedo clad oil baron. Underneath it all; the two trucks they are pretty much the same thing. Same as Ford vs Lincoln.
GroovyGeek
Boyan
'23 Bronco BD
What’s wrong with the current hard top? Am I missing something?
Someone has been living under a rock or is pulling our finger 😀
Mscdman
P
Denver
OBX
Nope. I’m genuinely curious. I don’t have an issue with mine except I can hear the wind. What’s the issue with the hard top?
GroovyGeek
Boyan
'23 Bronco BD
Where shall I start - It leaks, it rattles, it squeaks, rain pours from it straight into the cab, you need to bring your own insulation to reduce wind noise. Those seem to be mostly under control as of the late MY23. What is still a problem is that it cracks, branches puncture the surface with relative ease, and it is prone to delamination (don't try to use suction cups on it). And when the surface is punctured all you have below it is egg cartons that turn to mush when wet. ADV may be a shit company that has lied to its customers for 2 years, but their detailed analysis of the design shortcomings of the OEM top are worth watching.
As hikers say, there is light, and there is stupid light. In their attempt to make the top relatively easy to remove Ford made the top stupid light. You can drive the Jeep one into a wall and it will do OK. A few weeks ago I drove a rental Jeep at -40F temp before wind-chill. The hard top never frosted on the inside even overnight when the temps dropped by another 10 degrees. The aftermarket tops by AC and TOR are probably OK. The OEM one is just poorly designed and implemented.
Mscdman
P
Denver
OBX
Interesting. Mine is a MY23 (don’t know build date) and admittedly I don’t off road it and keep it garaged but I’ve only experienced wind noise.
I haven’t experienced any leaks, or any rattles, or delaminating or punctures. Again, I don’t offroaf it so branches aren’t hitting the top.
TangoHunter
Joel
Wisconsin
2022 Bronco 2016 Mustang GT
Are there bronco gen6 models with a non digital gauge cluster??? I assumed all had digital. You are saying some use needles?
You are correct, they are all digital. I’m just saying I wish they were released with needles. Needles are old and add to the classic nostalgia to me. I also prefer the smallest entertainment screen in the center dash. I just like everything simple and could care less about tech in my ride.
miami2823
James
Maryland
2006 GMC Sierra
Midnight_Blue
Jeremiah
Los Angeles
Many of the roof leak problems are user failure. People don’t understand the proper sequence of placing the panels, they don’t understand how seals work, and they don’t understand that dirt remains on seals until it’s cleaned off by someone.
MIC 1.0 here and other than a little creakiness when it’s cold, I’ve experienced none of the issues you described in 2.5 years and 50k miles of fairly rugged ownership.
Ninjak
Miami
Refresh, hmmm, well I do not expect much, maybe a few new colours, perhaps bringing back old colours, maybe a headlight slight change? Not sure how that would be pulled off, I would think some more refresh inside, maybe more colour options to match the different level trims, maybe a change in the brake lights, truly not much else.
As for Carplay, I run a 15Max and I have zero issues. Though I keep my IOS updated as well. I was a VERY longtime Android user, and I will say I actually like the Evil Empire auto app.
tock13
Tony
WA State
I hope for the refresh they realize the windshield is way too short and there is no need for the dash to sit up that high. A friend commented it was like the little slit you look out when driving a Sherman tank.
I have to agree, the belt line or whatever you call it is 3” too high. The only thing I find palatable on a G Wagon is the tall upright windows. It has fantastic outward visibility…which one wants in a 4x4 off-roader, and all the old classics had.
Hell, just being able to see a traffic light waiting at intersection, without putting my chin on the steering wheel, would be pretty sweet too.
GroovyGeek
Boyan
'23 Bronco BD
I was referring to the absence of rain gutters. When it rains and you either crack the window or open the door to enter/exit the vehicle you take a bath. Can be fixed with a $30 cheap plastic add-on but is still a significant design miss in my book. It is surprising that none of the aftermarket tops address this issue.
93_SVT_3503
JJ
BFE
2016 F150, 1967 Bronco U-14, 1993 Mustang Cobra
They need to sell off some of their stake in Safelite, and move the bottom of the A-pillar forward about 2 inches to increase the slope angle of the windshield. Routine windshield replacement shouldn't be a necessary part of the yearly maintenance budget, especially when they're continually on back-order.
ShiftyBronco
New york
Been hearing about the 2025 refresh for the Bronco. When do you guys think we will hear official news from Ford about the changes for the 2025 models? June/July?
Do you think they will make any changes to the Bronco Raptor?
Or, you think they will only refresh the lower trim levels?
What would you like to see changed on the Raptor?
For me I would like to see the fenders get more of a wide body kit with smaller fenders. That would be perfect IMO.
What are you guys and gals thinking?
I really hope they leave it alone and focus on mechanical/tech improvements. Ford has a tendency to butcher designs when they attempt to update them. The raptor, however, could use some help. I’d like to see them make it look less like an F150 and more clean like the regular bronco. Replace the garbage bin fenders with something better integrated into the design. I’d also like to see a manual transmission on the raptor, but I know that’s not gonna happen. And as others have mentioned, I’d like to see some nice colors back into the lineup, not another Fifty Shades of Grey.
Tex
Cliff
San Angelo
I'm sitting here looking at the narrow windshield vehicle on your profile pic and reading about your complaint of the Bronco windshield being too narrow, and the irony doesn't escape me.
You're not going to gain any visibility whatsoever by dropping the dash further down unless you consistently drive like an old lady looking through the steering wheel, and at that point you shouldn't be complaining about seeing traffic lights above you. For normal drivers you'd end up having a slightly better view of the hood, that's it. Adding more height to the windshield is going to make it look just as fugly as a gelandewagen. Making the windshield larger in either direction is going to offer more places for a rock to chip glass head on. The Bronco isn't for everyone.
Cactus Jack
OH
2022 Bronco Raptor
You bring up some interesting points. Ford was definitely more optimistic in the beginning. Remember the Bronco truck? Project abandoned.
The day I ordered my Warthog at the Ford Store (March ‘22) the owner showed me official Ford CGI renderings of the, ”Bronco” standalone dealership. They were working with Ford to make a custom store dedicated to Bronco vehicles. I wish I snagged some photos! Everything was unique to the location. Truly something special.
The design work was unlike any dealership I had seen before. On top of all of this, they were even planning to have a huge off-road course behind the store.
Nearly 2 years later, and we have not seen any Bronco Stores. Definitely agree that the high prices have turned people away. Local dealers cannot sell at MSRP any more. Broncos are sitting on lots.
At this rate, I don’t see Ford building standalone Bronco Stores anytime soon.
Getting into Ford's intended business plan is kind of pointless because they keep having to pivot and they are not where they thought pre pandemic.
Ford wanted Bronco centric dealerships, they also wanted EV only dealerships. There was going to be a Bronco lineup of vehicles, all sorts of plans that keep changing due to politics, buying trends with EVs, supply constraints, inflation, interest rates, the economy... not to mention union issues, plant retooling, bla bla bla. Oh and roof issues 🫣
So many things were coming out in the news, not sure what was realistic or just wishful thinking.
Ford had this incredible boom lined up, with the Bronco, the Maverick, and the initial hopes of the Lightning. The interest and demands, I believe, were unprecedented. They couldn't deliver on time, the costs went through the roof, the quality suffered, and the public lost faith in what should have been amazing time for Ford. Granted some of the circumstances were out of their control, but they didn't navigate the storm nearly as well as other auto makers.
Anyway, we have the Bronco, which was way overdue, I just hope they keep improving what needs improving and leave the stuff that works, alone. Change for the sake of change isn't needed, so leave the body style alone. 😎
Focus on improving quality and enough with special editions until the established trims are sorted out, roofs, tie rods and all.
And because, any chance I get ....
Bring back Anti Matter Blue.
