2025 Bronco Raptor uplifter diagram
Thrillingmouse6837
Heath
North Pole, AK
2025 Bronco Raptor; 2022 F-250 Lariat Tremor; 2013 F-150 STX
Hello out there. I'm looking for the diagram for the factory installed uplifter switches for a 25' Bronco Raptor. Everything I keep digging up is 24' or earlier. So far I'm seeing conflicting wire colors and would like to line those uplifter switches up. Photo of the chart, link to where its at online, or even a PDF would be great. Picture for attention.
Ford Bronco 2025 Bronco Raptor uplifter diagram 9376
Gene Dios
Atlanta
They all share the same owners manual per model year. The wiring assignments are listed somewhere in the 500 pages. Your vehicle has the manual in the infotainment system if you're worried that online docs aren't up to date for your 2025. The raptor is different than other Broncos in that 1 and 3 are swapped. This is reflected in the manual. But check what it says in the vehicle itself in case something was updated for 25.
Thrillingmouse6837
Heath
North Pole, AK
Thank you, I figured it out in the end. Searched that owners manual up and down, never found that dang diagram. Just used one someone had posted somewhere else.
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
I also searched the owners manual, for the 25 model year the diagrams were removed and I believe it points you to the dealership. It basically seemed as though Ford didn’t want folks doing the wiring of anything themselves.
Bschurr
NY
Ford Bronco 2025 Bronco Raptor uplifter diagram IMG_5030
