2025 Badlands Mudflaps Inquiry
CajunYankee
Scotty
MICHIGAN
2025 Ford Bronco
Hey guys got a question.
I've looked through the forums, and not finding a previous post. I have a 25 Badlands with the Sasq package and raptor running boards. I want to add mudflaps after just going down a muddy dirt road and seeing how much kicked up and into the back. Had the tops off, awesome by the way.
I'm not seeing an available mudflap with the set up I got.
Any help would be great.
VirginiaHeritage
Frank
‘25 Bronco HE
Check these out. The XL and XL Long
sizes are for Sasquatch. I don’t see the Braptor running boards as being a problem based on where they end behind the front wheel well, but you can email them to check:
https://rokblokz.com/products/ford-bronco-2021-mud-flaps
I just installed the XL Long rear-only set on my HE (Sasquatch). They appear to be very high quality and offer quick-detachment (if you choose that install option). No drilling. Flexible but not floppy and somewhat adjustable. Made in USA.
Ford Bronco 2025 Badlands Mudflaps Inquiry IMG_2111
Ford Bronco 2025 Badlands Mudflaps Inquiry IMG_2118
Ford Bronco 2025 Badlands Mudflaps Inquiry IMG_2109
OuterBanks
Matthew
23 Bronco
IAG just came out with new adjustable mud flaps. They are currently out of stock, but these looks really good. Think I’ll get a set when available again.
TheShark
Check these out. The XL size is for Sasquatch. I don’t see the Braptor running boards as being a problem based on where they end behind the front wheel well, but you can email them to check:
I just installed the rear-only set on my HE (Sasquatch). They appear to be very high quality and offer quick-detachment (if you choose that install option). Made in USA.
I'd second the Rokblokz, not the cheapest option but well made. I have them on my HLE with hoop steps.
Dr Dan
Dan
New York
24 Bronco
+1 for Rokblokz. I have them on my Wildtrak, realized very quickly my paint would not survive without them and wound up installing them in the snow. The Terrain MT's pickup and throw everything they find on the ground. The quick detachment part is important if you plan on offroading. When you come off a rock or ledge of any sort, you'll go right into whatever mud flap you have and likely break it.
jrollo7
James
NY
Range Rover Sport
Maybe Mabett with no drilling but not sure with the Raptor running boards.
Top Off Doors On
Alberta, Canada
2020 F150 Lariat, 2023 Tacoma TRD Sport
I just put these on a 2025 Badlands with the Ford raptor running boards a couple of days ago. They are expensive, but they fit perfectly. One version of the front flap has a cutout for the rock rail that extends into the wheel well; that's what my factory boards are attached to. The hardware is top notch and the mounting is secure. Took me about an hour to complete. Ours are 33" wheels and I didn't have to remove them - might be tighter to work with 35s.
I went with the Bronco logo; I'm glad I didn't let the cost deter me from buying them. They look excellent (IMHO of course).
https://www.truckhardware.ca/products/1123
https://www.truckhardware.ca/products/1123?variant=12038
jrollo7
James
NY
Range Rover Sport
an awful lot for flaps. But you,'re happy and it's your money.
Truckin
Not far enough away from Chicago
Bronco (retired)
Im not understanding why you need special flaps with the raptor boards. I posted a link above but here’s picks of where the raptor boards stop.
can you post pictures of yours ? If anything it needs something to hide the gap between the two
Ford Bronco 2025 Badlands Mudflaps Inquiry IMG_7429
Ford Bronco 2025 Badlands Mudflaps Inquiry IMG_7428
Top Off Doors On
Alberta, Canada
Sure - it's the rock rail that extends into the wheel well.
Ford Bronco 2025 Badlands Mudflaps Inquiry IMG_8655 Larg
Ford Bronco 2025 Badlands Mudflaps Inquiry IMG_8656 Larg
jrollo7
James
NY
Range Rover Sport
Not a Raptor
RobSC
Rob
Space Coast, FL
24 Bronco
I also have the Raptor steps option on a Badlands. Installed the IAG flaps, not the new adjustable ones.
You can see in the pic they butt right up to the flaps, but hasn't been a problem. The flaps also came with sticky back felt material that can be cut out and attached to the end of the rail, I don't think I used it for the fronts.
My Bronco is a 2024, don't know if that makes a difference.
Ford Bronco 2025 Badlands Mudflaps Inquiry 1749507676448-ii
SmokeStackMan
Jared
Pennsylvania
2023 Ford Bronco Wildtrak
I recently installed the upgraded Bro Flaps on the front. Good cost and working well so far.
I am going to get the OEM Gator Backs for the rear though. I just really like the look
aermtr
Don
Portland Or
broflaps.etsy.com
'20 GT500 CFTP, 65 Cobra and '23 Badlands 2.3 7MT
@CajunYankee search Bro-Flaps on this site. We are running g a special on new flaps for 6G members. Also a sponsor for 6G.
