2024 Bronco Raptor headlight fans
woodsman44
california
bronco
2024 Bronco Raptor lux package....headlight fans Always turn on for 10 mins everytime when I open any door and even when I pop the hood with motor off parked in garage.
Does anyone else Bronco Raptor do the same thing?...this just cant be normal, the headlights don't come on when I open the door or hood, why would the fans turn on when they don't need to be cooled?
The local Ford dealer here couldnt seem to figure this out.
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
Mine do not do it. In fact, I had no idea I had fans specifically for my headlights until I saw this thread.
Dan-O
Dan
Fountain Hills, AZ
The halos come on momentarily when opening door so that would explain the fans kicking on, but they do seem to run longer than they need to.
23OBX2.7
AB Canada
2023 Bronco
Probably just a test cycle that also clears out any humidity...very cool though.
Nails
Brad
MI.
2024 Bronco Raptor, 2020 Subaru Outback
My ‘24 Raptor has always done this. Doesn’t make sense to me, but I guess it’s normal.
woodsman44
woodsman44
california
bronco
The Ford dealer said they cleared some fault codes, he said one code was saying headlights were over heating per code which didn't solve the issue of fans turning on when parked and opening door every time....most likely a switch/wire/actuator thingy needs replaced.
