2024 Big Bend Sub-Woofer Install - Read This First!
steni
Stan
United States
BMW 540
I didn't. I was unprepared, but I do hear a noticeable difference with just the new sub.
I ordered the speakers upgrade and the woofer everything came out to about 380.00, I was thinking is there a replacement for the factory amp without messing around with the wires? like wire harness modification from factory to new, since I'm going to have everything open.
Hammy
Brdn
Torbay, Canada
2024 ford bronco big bend
That's great!! Did you put insulation when you did the swap?
I don’t recall putting in insulation.
I found this which looks like it might work... Sub Upgrade Kit for Ford Bronco – Enfig Car Stereo
Rivers90
Ben
Southern California
2 Door Base Sasquatch
2024’s come standard with the sub and amp.
Crappy, yes…. But they do come with it.
What I want to know… is there much improvement with just the sub swap? I already replaced other speakers in cab.
And all 2025 Broncos have a real amp and sub too.
steni
Stan
United States
BMW 540
Yes, I'm just debating on the amp, I know that the sub is really crappy. I really don't want to mess around with running wires and tackling forscan.
You will regret it if you don’t
23OBX2.7
AB Canada
2023 Bronco
I just Amazon Basics sound deadened sub enclosure getting nearly all interior spaces between ribbing, internal port, and double layer on exterior plus a cheap MB Quart 2 X 4 ohm.....no more rattles, buzzing and a noticable upgrade in output volume and quality tested with some very heavy bass EDM.
Hertz DCX 100.3 corners, Ground Zero BMW center, Hertz MP70.3 in pods.
I will use likely this now high density enclosure when I upgrade later...
steni
Stan
United States
BMW 540
Did you take some pictures
23OBX2.7
AB Canada
2023 Bronco
Oh and Hertz MP 6.5 3 ohm in kicks on printed spacers from my Mustang that fit perfectly.
No pics I don't take my cash paid crack free multi$K mobile to these jobs and always forget tablet anyway....
