2023 Bronco rear sagging under load... solution?
BigDan1
Daniel
St-Jean Baptiste ,qc.CA
2023 Sasquash Bronco 4 door
2023 outerbanks sasquash 4 door bronco
Problem: as soon as I load my 2 ev cycles and rack on back the rear end sags by at least 2.5 inches ,annoying because I plan to get a poonton boat ,
What would you see as a solution
Thanks
Dan,
Dan-O
Dan
Fountain Hills, AZ
I’ve been waiting for rear bag kit for this issue. But I have seen a guy using Sumo blocks/cushions for this.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Thanks
Dan,
Buy a truck
This, stiffer springs, and/or rake your rear end up unloaded to account for the sag
Those are about your only options other than getting a truck. The suspension is built to eat big hits, like rocks, ruts and roots. Unfortunately that makes it bad at hauling loads. The two aims are kind of counter purpose to each other
Aonarch
Jack Hoff
MT
What is the weight that you are putting on back there?
Tongue weight is only 350 lbs.
If you are using a hitch extender that acts like a lever and will lower how much weight you can put on.
Tongue weight also counts against payload.
Muffin Top
TX
JK, MK, KK, TJ, DN
Some of the aftermarket springs have progressive rears to bear up better under load. The purpose of those progressive rears is to improve load carrying.
BigDan1
Daniel
Total weight 153 lbs ,but maybe 200 lbs in cargo area also
Aonarch
Jack Hoff
MT
Check the part number of your rear springs.
The most cost effective method would be to install heavier OEM Sasquatch springs.
MB3Z-18125-K (engineering MB3C-18080-RBK) for the rear.
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
I'm thinking if he had a Sasquatch instead of a Sasquash he wouldn't be having this problem. Sasquash's are known to have weak rear shocks which leads to premature compression!
Gettyup
Rocky
So Cal
Bullitt Mustang, Expedition
I added an American Adventure Lab storage drawer, fridge slide and a mass shelve with gear add it’s almost 225 lbs and the rear sags about 2 inches. I talk to Bilstein and Eibach both are developing a load compensating spring and are still in RD
23 Badlands with Sasquatch pkg
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
Exactly right, hanging the load out away from the back of the vehicle does give it leverage. It could be that the rear suspension isn’t compressing all that much, but the weight hanging out away from the hitch actually uses rear axle as a fulcrum and lifts the front end like a teeter-totter.
BigDan1
Daniel
Gettyup ,
Thanks ,you know then what I’m going true
We need some type of cargo coils ( dual resistance ) 👍🏻
Gettyup
Rocky
So Cal
Wher I find out I’ll post.
Gettyup ,
When I find out I’ll post 😎
