2022 wildtrak randomly going into Manual shift mode
Zootsgeorge
Lucas
Canada
2022 wildtrak
hello has anyone had this happen to them my 2022 wildtrak randomly goes into manual shift mode and then goes back out again had it happen at highway speed and driving in town
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
That's not normal.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Zootsgeorge
Zootsgeorge
Lucas
Canada
2022 wildtrak
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
I had that happen a few time and it just happened about five minutes ago. The indicator shows it is in D but the trans is not shifting and you can hear the engine revving! I backed off the accelerator and it started shifting normally. Another weird thing happened tonight as well. Pulling away from a stop sign it bogged down and I thought it was going to steal but then it began operating normally.
Zootsgeorge
Zootsgeorge
Lucas
Canada
2022 wildtrak
Same thing happened to me just had it happen in traffic she bucked made a clunk felt like it wasn’t moving then started reving had to manually change gears with the button even this it’s in D on the dash and shifter luck I didn’t get rear ended
helifino16
Ron
Mount Sinai, NY (Long Island)
When it did this on mine, I realized that I was drumming the button on the side of the shifter to the awesome sounds coming from my B&O. Sometimes it gets inadvertently pressed while I'm resting my hand on the shifter as well. It does switch back quickly.
Fonz54
Lou
Monterey, CA
Did the indicator on the dash show that it was in Manual? The few times mine did this the indicator still showed it was in Drive.
helifino16
Ron
Yeah - it shows a 'random number' (the gear) on the dash.
With 10 gears, the unusual number threw me off as I'm used to a 5-speed manual.
Billnchristy
William
Georgia
2022 Bmw m440i gc,2022 BD 2dr, 1966 mustang
My wife has complained about accidentally hitting the button too. It will go into a temporary M mode if you hit the +/- and then return after a few seconds. I don't know why they bothered, it shifts so slow it's not even worth it.
Zootsgeorge
Zootsgeorge
Lucas
Canada
2022 wildtrak
so my bronco is at the dealer Now this is a known problem and they are doing a reprogram and Calibration there is a bulletin out about it
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Do you have the bulletin?
