2-Door Side Steps??
Gumball
2-Door Wildtrak and C5 Corvette
I bought a 2-door Wildtrak three days ago and I need to get some side steps to make it easier for my wife to get into the vehicle. (Neither one of us are spring chickens and she's had a knee replacement.) Can anyone tell me the manufacturer of the ones in the attached pic?
Thanks
Ford Bronco 2-Door Side Steps?? Bronco Side Steps
Jakethesnake
Jake
Philadelphia pa
2007 GX470. 2002 Suburban. 2016 Subaru Impreza
Havoc side steps. Takes some getting used too with the middle cutout but once you do they work good while being low profile.
Ford Bronco 2-Door Side Steps?? IMG_1751
Ford Bronco 2-Door Side Steps?? IMG_2144
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
Idk who makes the ones you posted but check out the AR magnum if you have a BD or BL. They are so awesome.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I don’t think those are the same ones the OP posted. They look different.
BigFootie
Wisconsin
Ok, I’m confused. Doesn’t the WildTrak come standard with steps? Are you looking for something lower than the standard ones? I think the hoop steps are lower than the standard ones. The ones you show might be a bit lower but not by much.
CM81
NA
Thanks
definitely go Rhino. I just ordered a different set than those. They ship fast. I would order asap as they have 25% off right now.
MayhemMike
Mercury
IAG is the manufacturer of mine. Connect to an existing factory rock rail. Easy on and easy off.
Ford Bronco 2-Door Side Steps?? IMG_1306
Ford Bronco 2-Door Side Steps?? IMG_1305
HeliPilot
Kenny
CT
2022 2.7L SAS
Far as I know, Outer Banks comes with steps, and Badlands comes with rock rails standard. WT comes with neither standard.
BigFootie
Wisconsin
I sit corrected!
Ford Bronco 2-Door Side Steps?? IMG_0936
2dogcamp
El Dorado CA
2021 F150 FX4
I wish AMP would make that small step single motor that ICON uses on their Broncos. It is so perfect for the two door.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
get something local from Rock Slide Engineering.
i just finished installation of their powered step and they’re perfect for the sasquatch application like the WT.
Fillups
Geoff
Cincinnati
2022 Bronco, 2010 Expedition EL
