2-Door Side Steps??
fourdayoff
Boulder City Nv
2022 Bronco Badlands/sasquatch 2.7
Rockslide Engineering x2, step drops 12", no loss of ground clearance, wife loves them. HWHL. Jim.
kpark_67
Aledo, TX
Just giving my 2 cents. I got the electric steps from Rock Slide Engineering for my 2 door Sasquatch Badlands. Mine work extremely well and making getting in and out even easier than with steps like the ones you pictured. I also got the extra armor plating to make the decent Rock Sliders.
HeliPilot
Kenny
CT
2022 2.7L SAS
I wish AMP would make that small step single motor that ICON uses on their Broncos. It is so perfect for the two door.
Not sure what the icon looks like, but I have amps on my 2 door.
Ford Bronco 2-Door Side Steps?? IMG_8532
PIG1
Farmland, IN
2021 Mazda6
I like those. I have a 2-door Wildtrak ordered and built. Waiting for delivery. Who makes those steps and do they mount on the factory rock rails?
Mjtermini
2022 2DR Badlands
They mount directly to the factory rook rails. When you order, select the logo color to match your Wildtrak badging. Company is iag. They are a Bronco supplier and have great quality
Ford Bronco 2-Door Side Steps?? IMG_2853
Gjpe04
Bloomington illinois
Any chance you could get me a measurement from ground to step? Or just a profile pic? Wanting to replace my boards as they do not come down far enough and I’m not concerned about ground clearance.
Mjtermini
2022 2DR Badlands
They have two versions. One like mine that are rail high and another that are lower.
Ford Bronco 2-Door Side Steps?? IMG_2965
Mjtermini
2022 2DR Badlands
So you can select which ever best fits your needs
Ford Bronco 2-Door Side Steps?? IMG_2966
Loop4re7
Sonora Ca.
Ram 2500
I put AMP power steps on my Big Bend 2 door SS. Easy in and out. Same steps as F150 other than they cut one foot off floor board. Ive had AMP steps on my Ram 2500 for 50,000 miles, No issues.
Jakethesnake
Jake
Philadelphia pa
2007 GX470. 2002 Suburban. 2016 Subaru Impreza
How are these holding up for you? I just ordered a set today.
Great. No rust. Still solid as when I put them on. I love them. My wife still hates them cause the cut out is right where she instinctively wants to stand.
I thought about getting something a bit wider for her because I’m getting a lift and 37’s and she’s really going to hate them.
here’s a pic of how they look today
Ford Bronco 2-Door Side Steps?? IMG_6670
Johnnyshore
Green Isle, MN
2025 Bronco 2-Door
That's great to hear! I'm pretty tall, and the first steps I had on mine hit my leg every time I got in or out of the rig (I would really prefer no steps).
Hoping that notch will work for stepping in/out without banging my leg, while giving the wife at least something to step up with.
Thanks for the update!
Doc Rocket
US
Ford Bronco, Base, Sasquatch
Go Rhino E-Steps. They use a motor on each end of the step, not one motor and an idler like the AMP steps. They are also a bit cheaper. The AMPs were one length, installer needed to cut the 2-door steps, but the Go Rhino E-Steps come at the proper length. I think they are a better product, but YMMV. You do need to line up some magnets to get the door-open switches working, but you also don't need to block the OBD II port, so that is kind of a wash.
Ford Bronco 2-Door Side Steps?? 20240921_091440
Ford Bronco 2-Door Side Steps?? 20240921_091505
