2-door Sasquatch is squatting in the back!
Tuco76
Portland, OR
Jeep Grand Cherokee
In general, I am quite happy with the stock Bilstein Sasquatch suspension, but when I am loaded up with camp gear the Bronco Badlands is squatting in the back. I don’t have a ton of suspension travel left, so I have to be quite careful off-road. Has anyone had any experience with upgrading the suspension in the back to reduce the squatting without making the ride terribly uncomfortable when the truck is empty? I am not planning any tire size upgrades I and I want to stay with 35s. Any suggestions are appreciated.
JT58Bronc
JT
Fl
2022 Bronco, 2021 Miata track Edition
I wonder this too. The one time we had a long journey in our 2 door Sas to Ga hauling all of our gear we had sag in the back too. We had to go down a lot of dirt roads and a hill climb at the end to get to our remote cabin. Lot of weight was back there and a full tank of gas adds to the weight and sag.
CitrusBronco
Everglades
Citrus county, FL
Everglades
Any airbags available for the Bronco yet? Small trailer also a good option.
Noremac
Arkansas
2021 Bronco Badlands Sasquatch
unsure what the difference is in spring rates between the 2 and 4 doors, but I can fold my seats down, load 100% of my camping gear for family of 5 in the back, and cannot tell a difference in ride quality.
Maybe look at the part numbers between the two and swap springs to see if theres a difference?
Preheateddinner
S.
22 Ford Bronco BB 2D
MFP2241
@Tuco76 - Just wondering if you have the tow package?
Tow package wasn't available with my '21 Base Squatch, so I installed the hitch myself. As a fix I was contemplating changing my rear springs for the stock "F" springs in the chart below. But, if you have the F springs and still have I same issue, I guess my assumed fix won't be effective.
Ford Bronco 2-door Sasquatch is squatting in the back! Screenshot_20230531_234137_Firefox
Tuco76
Tuco76
Portland, OR
Jeep Grand Cherokee
Thanks for the tip! I have a '22 with a dealer-installed tow hitch, since the factory tow hitch (for lack thereof) kept me from getting a production slot. So, I assume I have the "A" type springs on my 2.3 2-door. I will definitely look into the "F" or "C" type springs.
Tuco76
Tuco76
Portland, OR
Jeep Grand Cherokee
I heard the same from a friend that has a 4-door as well. I suspect the sagging in the rear is a 2-door specific issue.
Tuco76
Tuco76
Portland, OR
Jeep Grand Cherokee
Noremac
Arkansas
To quantify the amount of weight I have had in the back, I put 14 80lb bags of concrete in the hatch area and drove home still not on bump stops. The Bronco definitely knew the weight was there though
TxCatalystMan
Paul
Kemah, Texas
2007 Porsche 911 CarreraS
I plan to haul quite a bit of gear and dogs too so I replaced my Fox 2.0' stock Bilsteins with these. They're adjustable to fit your needs, without removing the tires and the ride is an improvement over stock!
Eibach 2021+ Ford Bronco Pro-Truck Coilover 2.0 Front & Rear — Panda Motorworks
Blue Hen
Delaware
99 Toyota Tacoma
When I first got my 2 door Sasquatch. I started detailing it in my garage. Pulled the spare tire off to apply ceramic coating on all painted surface. Was pulling the bronco outside to get better lighting I hit the handle on the garage door with roof rack. Just taking the spare tire off raise the suspension. 2 door has a very soft suspension.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
Have the big folks sit up front.
