2.7L vibration pulse and rough idle issues
BroncoFrog
Drew
DFW
Bronco Badlands 2023
I have seen some threads that indicate some similar symptoms. But recently (around 12 months and 25k miles) my Bronco Badlands 2.7L began to roughly idle (noticeable shake in steering wheel and seats) between 800-1,100 rpm (the cold start range for me). After it warms up and lowers to 500-600 this goes away, however a noticeable pulsing vibration is then felt. Very rhythmic, perhaps every second. Enough to shake the headrests and vibrate your back, but minimal. Not misfire level, and way too repetitive and well-timed to be other issues. At first the dealerships stated it wasn't there, then that it was aftermarket intake or exhaust (I had done the intake after the issue started). I had kept all factory items and it happened if they were also installed so ruled that out. Then the dealership and service manager stated that "that's just how the bronco engines are" that it is normal to constantly "feel like a misfire almost in these Ford engines". Weird that it went from saying it was aftermarket products to totally normal but whatever. @Ford Motor Company Can you confirm that this is "just the way Bronco's are"? Seems like not everyone has this issue and mine did not. I have not been thrilled with the quality and two dealership +a service manager stating that since there are no codes and nothing obvious that they will just leave it as is. Anyone else have this issue? Anyone else finding solutions?
Many point to the AC, but would that kick on and off so frequently (again, every second). I thought about removing the serpentine belt briefly to see if it was related to accessory drive, but I am very new to any and all car work so I have kept my involvement limited.
Dan-O
Dan
Fountain Hills, AZ
I have a 2.7 and I do notice a slight vibration difference when I have AC on, especially in steering wheel at idle. Not saying this is your issue, but I have confirmed it to be the case with mine.
BroncoFrog
BroncoFrog
Drew
DFW
I have a 2.7 and I do notice a slight vibration difference when I have AC on, especially in steering wheel. Not saying this is your issue, but I have confirmed it to be the case with mine.
Even if AC is off I have that shake (waiting a few minutes too after turning off). I had some vibration when AC was on but it seemed to be due to dirt settling on the bottom of the radiator fan and making it spin off-balance.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
1st 75th ranger
jeffrey
nj
my 21 bd 2.7 does it also but 0 codes show so dealer says no issue
n0xlf
Castle Rock, CO
2003 Mustang Cobra
I have the cold start vibration (not always, but often) at 13k mi. Nothing else noticeable though.
BigMeatsBronco
Allan
2021 FE 2 door
time for a set of spark plugs buddy, my fist set lasted a whopping 25k...
Toonces
Devon
Jersey City
Dodge Challenger R/T Classic
I had this happen on an old Honda back in the day, it was a broken engine mount.
Calm horse
MO
Georgia
17 f150 king ranch
Out of curiosity.
What type of fuel are using? Brand and octane.
BroncoFrog
BroncoFrog
Drew
DFW
Out of curiosity.
93 from a variety of places. Chevron, Costco, and whatever is on the way home from work.
