2.7 not as responsive as a 2.3
65CarryAll
IL
The last 2 door Blazer (ZR2)
The 2.7 has twin smaller turbos to reduce turbo lag. If your 2.3 feels more responsive it's not the single turbo, it's something else.
Bronco21Maybe
Justin
2015 F150, 202X Bronco, if it's ever built
Reason #2 I got the 7 speed instead of an automatic for my Bronco.
89Bronco2
Lance
Jersey
2023 Bronco OBX
I've had both 2.3 (2023), and 2.7 (2025), loved both. That being said, both benefit greatly from ProCal tune, once installed shifting from 1-2 is much smoother, and ever mode feels like it was bumped up one level. By that I mean with tune, eco feels like normal mode on a non tuned enough, normal (tuned) feels like sport etc.
I am thinking of getting the Ford Performance Tune on my 2023 2.3L- would you say its worth the $?
A while back I would have said yes.
Today though - go with one of the custom tunes that are now unlocked for about the same price
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
The 2.3L has a "twin-scroll turbo" which has less turbo lag than the regular turbos used on the 2.7L which uses two " mono-scroll turbos". Stock horse power is 300hp for the 2.3L and 330ph for the 2.7L, not a huge delta, but the 2.7L has quite a bit more torque.
23OBX2.7
AB Canada
2023 Bronco
Something is not right. I have a 2025 with a 2.3 and a 2023 with a 2.7 and the 2.7 is an absolute rocket compared to the 2.3. If you so much as breathe on the throttle the 2.7 comes to life. The 2.3 is adequate but it’s anemic compared to the 2.7. We have the Ford tune on both engines and I run the 2.3 in sport mode at all times to give it a little life. The 2.7 I never even bother with sport mode. Both Broncos are the identical set up other than the engine size.
I use Sport all the time in my Procal 2.7 with 93.
Ryneb
Ryne
Portland Oregon
2025 Bronco
I say yes, but in your case the main benefit is probably moot. ProCal comes with a 3 year/36k mile warranty. Since yours is a '23 probably not a big deal.
I haven't looked into any of the aftermarket tunes, so can't really comment on any of those.
JL8jeff
Ewing, NJ
My wheels/tires are stock Sasquatch. Kid (2.3l) has same tires as me, but aftermarket wheels. So I'd say neglible.
My base Sas 2.7 2 dr had some bad throttle lag (remember, there is no turbo boost in 1st gear due to torque mgmt) so I bought one of those throttle boosters which definitely helped make it more drivable. I already had a 3" cat-back exhaust on the truck and decided to get the Procal tune (found it for sale at half price so not a bad deal). The Procal helped big time with the throttle lag so I got rid of the throttle booster and I run normal mode all the time, sport mode is too jumpy. I then added Mishimoto intercooler and charge pipes and it got even more responsive. I added the CVF intake an GPE ported TB and the truck really drives the way it should have from the factory. Even with some lift and 37's, it jumps off the line and I'm getting better mpg than stock. I know we shouldn't need to modify things, but the factory (no matter which manufacturer) has to meet emissions, sound, safety requirements so everything is detuned.
One thing you mention comparing to your son's truck with the 2.3, his aftermarket wheels are roughly 10 lbs lighter per wheel and that will make it respond quicker to the throttle.
KillerPenz
North East
After reading your post, you can see why I'd rather Ford just drop a V8 in these things. And not some stupid Jeep 392 for $100k, just make it a $5k add or whatever for a standard V8, call it a day. Look at everything you had to add to your Bronco just to fix this one simple issue of turbo lag.
heavyD
Calgary, Alberta
2025 Badlands 2-Door
The 2.3L has "twin-scroll turbos" which have less turbo lag than the regular turbos used on the 2.7L which uses two " mono-scroll turbos". Stock horse power is 300hp for the 2.3L and 330ph for the 2.7L, not a huge delta, but the 2.7L has quite a bit more torque.
That's kind of out of necessity seeing the 2.3L turbocharger is larger and needs the twin scroll to reduce lag associated with larger turbochargers. Twin scroll is not applicable to twin turbo V6 (one turbo for 3 cylinders) because the technology requires evenly paired cylinders so instead to reduce lag they use tiny little single scroll turbochargers that spool up quickly.
JL8jeff
Ewing, NJ
I didn't have to do anything to fix turbo lag, I did most of the mods because I knew they would help the overall drivability of the truck and they did. What you're calling tubo lag is throttle lag and that can be programmed out easily with a custom tune and is actually adjusted with the Procal tune. The stock automatic shifting programming sucks and a tune helps that a lot as well. Even with a V8, it would have the torque management in 1st gear and throttle lag to protect the transmission. GM does the same thing with the 5.3 trucks.
not on the rug
NJ
2024 Wildtrak. 2011 BMW X5M. 2024 Nissan Pathfinder Platinum
Don't bother. He's hung up on the idea that this is a turbo lag issue when it's not. Nothing me, you or anyone else is going to say will apparently change his mind.
KillerPenz
North East
You say easily, I say another $600+ out the window. When I never had this issue in the past with non-turbo engines.
Wouldn't a pedal commander help with throttle lag? Have that installed, still not the same as driving a non-turbo engine.
Bronco21Maybe
Justin
Gearing and sports mode make for a peppy little vehicle. But I have the 7 speed. If I wanted to spin the tires or race, I would have bought a sports car.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I suspect the 2.7 Badlands has a very soft off throttle map due to its focus as a rock crawler. Sport mode changes that of course. Maybe you should do your comparo against a 2.3 Badlands - both in normal drive mode.
