2.7 engine failure tracking thread - Ford Please!
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Don’t believe so. Ours is a 2 dr build and never received a finalized build date till October. Build date was originally in July then went to august then September and finally postponed to October because of hardtop fiasco.
With regards to finding out the engine build date, here is a post with a screen capture showing you where to look. Maybe your dealer can take a photo and text you.
jeremy.wilson237
Jeremy
Ford Bronco, Ford Super duty, Jeep Wrangler
thank you, I’ve emailed the service manager with that photo to see if he can get me that info tomorrow.
navi
Navi
CA
73 Bronco
It looks like blown engines probably have build dates from mid June through October...at least.
Ford Bronco 2.7 engine failure tracking thread - Ford Please! madhu
da_jokker
Jeep Wrangler JKUR
And yet there are so many people on here that will argue that this is not an issue.
So I wonder how many valves come in a "batch"?
Snowdogyyz
23 Ford Bronco Wildtrak
I love the argument the fanboyzz make that this forum is a small percentage/representation of bronco owners so it’s probably not an issue at all. That makes absolutely ZERO sense! If this forum is a small percentage and we have 12 REPORTED blown engines, that could actually mean a way bigger problem than we even know! And it’s not like there are thousands of 2.7 broncos out there to begin with.
But that’s why this thread is here- collect data and find out as best we can if there is or isn’t a widespread problem. Ford certainly won’t come forward.
Jazer
Jessica
2.7 OBX
There is definitely something going on. My concern is that there are a lot more that are affected but haven't hit their breaking point yet due to being so new still... so this issue could rapidly become more prevalent.
HOPEFULLY it's just a small number of affected vehicles.
Still want my 2.7.
OX1
jackson nj
59 Brd, 70, 78, 79 Brncs, 84 LTD 331, 86 Cpri 5.0 Trbo, 17 Fsion Sprt, 21 GT 500
If there is a dozen here, shouldn't there be at least a hundred 2.7 F150's?
Jazer
Jessica
2.7 OBX
Not necessarily.. If it was a bad batch of valves, or retainers, etc... It could have been the one batch shipped to the Bronco engines. Despite being "the same" there are different part numbers between the two engines (f150 vs Bronco). Haven't done much research myself, maybe someone else can chime in that knows more
jeremy.wilson237
Jeremy
Still want my 2.7.
from the sound of it they arent going to have to wait long. Ours only made 2,000 miles
segt1915
Georgia
2014 4Runner
this makes more than a dozen 2.7L blow-ups (i.e. engine dropped valves) reported here in B6G . . not including coolant hose failures, et cetera
Here's another post . . details
how to determine your engine 'build date' from the label info . . example photos below
Where are the "more than a dozen" blow-ups? The tracker in this thread lists 5. There are a couple more mentioned in this thread, and a couple more "saw it on facebook" references. That's still a 35% increase away from 12+.
segt1915
Georgia
2014 4Runner
there are several more not listed in this thread . . . you'll have to search around . .
personally in B6G I've seen 13 of them . .
I'm an interested owner of a 2.7 Bronco that sounds like a diesel engine for two seconds on start-up. I've searched around. Every failure that is floating around in different threads is referenced here. If you're going to throw around the 13 number with authority maybe you should compile the list.
Snowdogyyz
I have seen more than what’s listed in this thread too. I’m not going to spend the time going back to find them all. You either believe it or you don’t.
