2.3L Firewall Access Grommets
TXDOZER
Les
El Paso TX
2022 Bronco Basesquatch & 2020 Escalade
I’m working on air hose routing from my 2.3L engine compartment to the rear for an Apex CRS. I can’t locate the driver side grommet that everyone is talking about. Is the 2.3L different? Has anyone found another drivers side firewall access?
mellout
mike
california
bronco
Do you have a stick or automatic not a 100% sure but heard the stick does not have that entry hole
TXDOZER
TXDOZER
Les
El Paso TX
Manual stick.
Chrome_Pony
Chrome
The Great Land
Right. The manual Broncos use that hole for the clutch cylinder passthrough.
PWillette
Parrie
Maine
I forget the optional location for the manual. I believe @RagnarKon posted a thread...try a search.
jsoa
Jose
Delaware
2024 Bronco 4dr
Area51BS
Ron
Badlands non SAS 4dr 2.3
Very clean!
Thanks. One side as you can see holds the bushing. ABS on other side of firewall and through bolts compress the assembly on the firewall.
