2.3 Underboost / Underpower
Djd7
Northeast
BD
For context:
- 2.3 Auto BD, 2.4k miles
- Followed 1000 mile break in
- Turbo pressure seemed normal compared to other 2.3 Broncos driven
Having an issue (I think) where the Turbo does not build any pressure(e.g. 0 up to 3-4k RPM).. it will build up to ~5-7 lbs of pressure at higher RPM (really have to get on the throttle). The blowoff seems suppressed and power seems to be below what it used to be.
Checked some of the hoses visually and did not see any loose clamp/holes. Scheduled time with a dealer for them to check it out.
Has anyone experienced this? / What's the impact on the engine if the turbo is not assisting if I drive it?
HotdogThud
mk6 gti, '21 MoarDoor
not much harm can come to it, it'll just be down on power. ECU's are pretty good about going "oh, I'm only getting X amount of air, i'll only dump Y amount of fuel)
Things it could be though:
wastegate stuck/malfunctioning
boost leak (intake hoses or charge pipes)
intercooler issue (pinhole leak or something)
Not sure that you're seeing regular boost pressure though. even getting a tiny bit on the throttle and running it up to 4-5k, i'll see 7-10 psi. flooring it and running up to redline it will consistently hit 16-19 psi.
DogHauler
Chuck
2022 Badlands Sasquatch 4dr 2023 Black Diamond 2dr
What octane are you using?
Chuck_Ruck
Chuck
Arizona/Nomadic
F150, Wrangler, Eldorado, Harley, Triumph
One time hit gas & brake simultaniously(dont ask why), in eco mode; and the screen came up with a prompt "Power reduced - Ok". And so i learned, never do that again.
Did you do that?
Djd7
Djd7
Northeast
BD
Did you do that?
Nope
Bronco21fan
Angelo
NewJersey
For context:
Have dealer look at it
jphillips2
Jason
Killen, AL
2020 F150 Supercrew 4x4 Sport 3.5 ecoboost
For context:
Did you have any lights? My BB 2.3 Auto received an MIL light and a Reduced Power light. The code is for Wastegate Stuck Open. Same exact symptoms as you. Power feels ok, but not what it should be. Boost will NOT exceed 7 no matter what and is usually in the 0-2 range.
I removed the c-clip and rod to wastegate and was able to move the rod manually. I then put it all together with the wastegate in the open position. I also reset the codes. Within a minute of driving I got the codes again, and check to see if the wastegate had actually closed back...which it had.
Dealership confirmed the same things. The computer only tells them to "Repair as necessary" so they ordered a new electronic actuator (these are not vacuum controlled like others) to try first. Been waiting over a week for it to come in. If that doesn't work, he said he'll start tracing down wiring to see if something is amiss.
This started with 110 miles on it. Now has 1600. Drivability has still been good, just seems a little down on power and fuel mileage seems to be a little lower than what it should be.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Did you do that?
Weird I thought that's how you take screenshots from the front cam.
BaseBD
Missouri
2021 4D Black Diamond
@Djd7 Did you get resolution on this? Having similar issue.
Bmisk19
Ben
Canton, MI
22 Badlands 2Dr 7MT
This happened to me at 50 miles actually- dealer had to replace the entire turbo.
Saltlife4shore
Anthony
New Jersey
2021 Big Bend
I'm having the same issue. Light acceleration from 0 to 50 and I can see zero boost the entire time. If put a little more throttle into it I can get 2-5psi. If I mash the pedal to the floor I may see 12Psi. Sport mode mash will go to 15psi. It's just strange. I remember when I got it at 155miles on the OD if you just tapped the throttle it would make boost. I'm also experiencing a sluggishness, shudder of maybe the trans. When cruising At almost any speed the trans just wants to upshift, and the rpms fall to 1200-1500 and then it shakes or shudders cause there's not enough power to keep the speed. It's like when starting a stick shift off in 2nd or 3rd.
Saltlife4shore
Anthony
New Jersey
2021 Big Bend
I also noticed a couple days ago when the auto start stop kicks on and the truck shuts off, the boost gauge on the display keeps flip flopping between 0.0 and 0.1 continuously until I let off the brake and the truck turns back on.
Djd7
Djd7
Northeast
BD
I have had no success with one dealer. The techs wrote it up as "operating normally" as it has some boost.. but not the same. Need to have them test drive a mannequin and ours side-by-side.
Has anyone had codes come up? seems like there have been ~15 unique reports of this on B6G so far.
