17" vs. 18" wheels
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
I'm thinking of upgrading my wheels soon - but keep thinking that 18s would look nicer.....But at what cost?
- Comfort loss going from 17s to 18s?
- Decrease of Off Roading capabilities?
- etc......
I'm likely not doing any major rock climbing/crawling stuff, but do want to retain most of the Bronco's off-Roading prowess :)
I'm choosing between the KMC Recon (Satin Black) or the ICON Alloys Thrust (Silver/Alloy color)
Southern Girl
1974 Bronco/2024 Wildtrak
I wish I had 17" wheels, but I can't find any I like that don't have a big offset. I don't need paint chips.
Erock
US
2018 F150 Alpine edition
Standard badlands wheels maybe, they look really similar to yours IMO. Though I believe they are a 1/2” wider and 20mm less offset… so, all in all they should only poke 1” more than what you have now.
Keep in mind that I could be wrong, so no guarantees… lol
BigGarnet
‘21 Bronco
- etc......
I would go 17s...better for airing down/off road, and they look better on a truck meant to be off road. More tire choices too in that segment (off road tires).
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
- etc......
I'd stay with 17" rims. They look better and perform better.
Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
I went from 18 stock OBX wheels to 17 Badlands. Liked the BL rims better. Got 295/70/17’s on . Very happy
Any issues with crash bars? Are those 17" rims? Nice!
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
- etc......
Neither of which is going to give you a noticeable advantage/disadvantage in anything performance related. Comfort is going to come more from the size of sidewall and PSI in the tires, and unless you're going to be running rubber band tires on either the 17 or 18 inch wheel, the comfort is going to be damn near identical. Off-road capabilities are again going to be negligible. Unless you're crawling, which you say you're not, that extra 0.5" of sidewall isn't going to matter. The capabilities are going to come more from what tire you run and how much air is in them as opposed to an extra 1" total of sidewall.
SeaVee
Greg
Va Beach
2002 2500 Suburban, 77 Bronco, 2001 Cherokee
I went with the 17 Badlands rims b/c I think they look better than the stock OBX rims. Plus a 1/2 inch wider. Took my crash bars off before the install, not sure if it was necessary.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Go ahead and get those 24’s you’ve been looking at. No one here would ever judge you for it. 😉
24 = NO WAY :). But I get how you would have assumed that. ;)
kodiakisland
Arkansas
On a 4wd, rubber looks better than wheel. Bigger wheels will always look out of place on any thing classic or 4wd to me. I'd vote for staying 17.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Thanks for the guidance and also pretty much exactly what my good friend here said :)
Lucky13!
jeff
Charlotte
Ford Flex
I had the exact same debate. Really wanted 18's but ended up going with 17's mainly due to the huge cost difference ($550 for my setup). Love the way it came out but have to say there are days I wish I had gone with the 18's.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I wouldn't do 18s, tire selection has been shrinking. Right now the most tire options are 17s and 20s.
How big of a tire do you want? What load rating? I would do a 265/60r20 on a daily driver and you can get a fairly aggressive tire in that size P rated.
