- Jacob
- Aug 26, 2021
- 29
- 313
- 555
- Sanford, FL
- Website
- www.holley.com
- 2022 Bronco
- Undecided
We've added support for all 21-26 Bronco models (including BRaptors!) to our awesome Flashcal+ mobile options device!
Part number SC-MOD allows Bronco owners to calibrate the speedo, control TPMS settings, change vehicle convenience settings, adjust audio controls, configure lighting options, and more!
The Flashcal+ is a mobile solution, with a Free iOS or Android app available for complete control from your smartphone. All options are easily managed through an intuitve and easy to use app, allowing for simple on/off or enable/disable selections. No more writing code! No more guessing! No more hoping you didn't create a new problem! And best yet, no more dragging a laptop out to your bronco to make changes.
At $199.95, this might be the best value in the Bronco aftermarket!
https://www.holley.com/products/tun...ers/bronco_flashcal_plus_wireless_calibrator/
Check out this list of features and options, available right out of the box!
Audio Configuration
Audio Configuration
- Equalizer Assist - Enable/Disable
- Fake Engine Noise - Enable/Disable
- Active Noise Cancellation - Enable/Disable
- Front Door/Dash Speakers - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker / B&O Speakers
- Front Center Speaker - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker
- Rear Pod Speakers - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker / B&O Speakers
- Subwoofer Speaker - No Subwoofer / Subwoofer
- Sport Mode - Enable/Disable
- Rock Crawl Mode - Enable/Disable
- Baja Mode - Enable/Disable
- Off-Road Mode - Enable/Disable
- Note: Available on 2026 Bronco 2.3L/2.7L and 2022–2026 Bronco Raptor 3.0L.
- Slippery Mode - Enable/Disable
- Tow Mode - Enable/Disable
- Note: Available only on 2022-2026 Raptor 3.0 models
- Eco Mode - Enable/Disable
- Note: Available on 2021–2026 Bronco 2.3L/2.7L only.
- Mud/Ruts Mode - Enable/Disable
- Note: Available on 2021–2025 Bronco 2.3L/2.7L only.
- Sand/Snow Mode - Enable/Disable
- Daytime Running Lights - Enable/Disable
- Fog Lights - Enable Fogs with high-beams (Bambi Mode)
- Lock Feedback Light - Enable/Disable
- Headlamps Position - Auto Lamps / Last Known
- Auto Lights Delay - 0s / 5s / 10s / 15s / 20s / 60s / 120s
- Recalibrate Speedometer - Enable/Disable
- Tire Size (Imperial & Metric) - Height: 28.25"–36.25"; Includes Aspect Ratio input
- TPMS Alert Threshold Front - 1–90
- TPMS Alert Threshold Rear - 1–90
- TPMS Enable/Disable - Enable/Disable
- GPS Based Tire Size Wizard
- Auto Lock - Enable/Disable
- Auto Relock - Enable/Disable
- Auto Unlock - Enable/Disable
- Door Chime - Enable/Disable
- Engine Shutdown - Enable/Disable
- Global Windows Down - Enable/Disable
- Global Windows Up - Enable/Disable
- Honk Warning - Enable/Disable
- Navigation in Motion - Enable/Disable
- Panic Alarm - Disable / Single Press / Double Press
- Power Point Timeout - Disable / 10m / 30m / 1hr / 75m / 3hr
- Remote Start Duration - 0s / 5m / 10m / 15m
- Remote Unlock - Driver's Door / All Doors
- Screen Config - 8-inch Landscape / 13.2-inch Lincoln / 13.2-inch Ford / 12-inch Landscape
- Seat Belt Minder - Enable/Disable
- Silent Mode - Enable/Disable
- Startup Chimes - Enable/Disable
- Steering Wheel Temp - 75°F–102°F
- Turn Signal Volume Down - Enable/Disable
- Auto Start-Stop - Enable/Disable
- Note: Available on 2021–2022 Bronco 2.3L/2.7L and 2022 Bronco Raptor 3.0L only.
