AIGMUX
Lux Sponsor (Level 2)
Los Angeles
bronco 2022
Vehicle Specific Custom Fit: Perfectly fits 2-door & 4-door Ford Bronco 2021/2022/2023/2024/2025/2026 that comes with factory crash bar or Sasquatch Package equipped models (NOT for Bronco Sport)
Full Sealing Protection: Delivers 100% tight sealing to block sewage, dirt, mud, snow, ice and other road debris from getting into the axle holes. Effectively prevents corrosion and mechanical damage to your front axle system during off-roading and daily driving.
Play Installation: Super quick and hassle-free setup—simply push the axle plugs fully into the reserved holes. No drilling, no modification, no damage to your original vehicle structure at all.
All innovative products require promotion and wider adoption. Therefore, we are currently offering 5 spots to receive this product for free. In exchange, we simply ask that you post a photo review on Amazon.
If you are interested, simply reply directly with "I need one."
We will randomly select 5 owners to contact you regarding how to obtain it.
Terry B.
Terry
ohio
2025 bronco badlands
I need one
CalvinT
Calvin
Phoenix, AZ
I have a set. I like them. Should be included at the factory.
EG WT 4DR
NY
24 Braptor, 22 Explorer ST
I need one.
Archerman907
Kyle
Idaho
2025 2DR Badlands SAS Desert Sand
I need one
FoCoBronc
Colorado Springs
‘26 BL - previous ‘22 OBX, Tacoma, X3, MDX, Bronco II
Looks nice. Does it create water issue not allowing drainage and dry-out? I remember seeing pics of frame structure on ford trucks where they rusted out as no drainage capability. But-minor detail on crash bars.....
totaljustice
Kevin
Middle Sackvegas, NS
I bought a set of these a while ago from a different seller and found while installing that the caps for the trailing bar interfere with the Mabett mudflaps. Not much but enough to make reinstalling the flaps a major PITA. I'd buy them again but just be aware that you might have fitment issues if you're running certain mudflaps and might have to perform some redneck engineering.
Bswag
Bob
PA
I need a set
