RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
Hey Bronco Nation. Its been a while since I dropped the original Auxiliary Retrofit DIY - How To write-up, almost four years ago. Since that time, there's been a lot of solutions that have hit the aftermarket. A few of you have asked for some help, or brought up some great alternatives and I thought it useful to share that information with the broader community.
Original Upfitter Retrofit DIY Writeup Here:
https://www.bronco6g.com/forum/thre...talled-diy-writeup-instructions-photos.35388/
First, Ford Performance just released a kit for installing Auxiliary switches thats a bit easier than the retrofit route. Downside is you're only getting 4 switches vs the factory 6 setup. It also looks a little incomplete, IMO.
Ford Bronco Auxiliary Switch OEM Retrofit DIY Alternatives 1000061168
BRONCO AUX SWITCH KIT| M-9100-BR | Ford Performance Parts https://performanceparts.ford.com/part/M-9100-BR
Hunting around for alternatives, I found these very similar, OEM style Auxiliary switch kits on Amazon that give you the factory look while avoiding headache messing with the factory installed BCM-C under the hood. Much easier than the retrofit, less expensive than the Ford option, and they give you 6 like off the assembly line vs the Ford Performance kit that's only 4.
Ford Bronco Auxiliary Switch OEM Retrofit DIY Alternatives 1000061157
Ford Bronco Auxiliary Switch OEM Retrofit DIY Alternatives 1000061166
Ford Bronco Auxiliary Switch OEM Retrofit DIY Alternatives 1000061160
Here's links to the kits out on Amazon
https://amzn.to/46VslQU
https://amzn.to/47gXvRB
https://amzn.to/46WDPUc
https://amzn.to/4hip6Xb
Ford Bronco Auxiliary Switch OEM Retrofit DIY Alternatives 1000061171
I also know there's a bunch of diehard Auxbeam fans who swear by theirs and the ability to customize the buttons. For the money they offer a similar solution at a fraction of the price, with drilling to mount the touchpad as the main downside. Plus they're on sale right now, making them a very attractive option.
https://amzn.to/3L2IgEh
In the case with all of these solutions, they are a bit more straight forward vs the more expensive OEM part swap option.
Have you needed to do a retrofit to your Bronco's setup? If you have some words of wisdom drop those in the thread below. I'd love to hear what worked for your personal build.
-Rusty
jtgensler
Jamison
Clarion, PA
2022 Bronco
Bit pricey, but the Diode Dynamics D-Switch is really nice.
Haven't put one in a Bronco yet, but on an F350, it's working pretty well.
Fast Eddie
Ed
NY
2025 4Dr OBX, 2025 Navigator BL
I went with the hanspilot up fitter switches for $320. Install was simple and they work great and look factory.
I have no idea why the Ford Performance option went with only 4 switches... they didn't even center them and left the blank where the other 2 switches would have went.
also, didn't they change the name to Ford Racing, or are they keeping the Performance name?
RustysBronco
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
Sounds like they still have a bit of an identity crisis.
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
I did a 6 when I bought mine. Still waiting on lights to arrive so I haven’t installed.
Ford Bronco Auxiliary Switch OEM Retrofit DIY Alternatives IMG_2983
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
Yeah, I'm sitting here scratching my head trying to figure out the reasoning behind the four switches versus six, and my OCD is freaking out because of the spacing....
Oh, it's Ford Racing again, as of a few weeks ago.
RustysBronco
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
