SierraBronco
Have this already typed up in the build thread, but most aren’t interested in seeing the latest stickers one has installed or how many rubber-duck-color-matched light bezels are now being ran. Absolutely I get it. Plus-it’s mofuggin Pritchett. The “hardest public” trail in Moab. Or so I’m told. So in hindsight it seems appropriate that the trail has it’s own thread.
We went into it with the mentality that we had nothing to prove and that flipping the bronco over for a nap makes it difficult to continue wheeling. If we don’t get an obstacle on the first few tries, time to bail out.
The first hilarious part was simply dropping in. It’s a few steps down, each one a couple feet high, but what was funny about it was long before wifey ever started wheeling, we showed up to Pritchett not knowing what it was. We hiked in to this particular spot and I told her we’d drag a little, but it wouldn’t be a problem. She was not about that life. Not one bit. Made a good point that we wouldn’t make it out if it was a down and back trail. Now? She just drives down it like it’s nothing 😂
The trail itself is everything you see on youtube, just worse. But between the obstacles, it’s really kinda boring. Absolutely gorgeous scenery though. And when you get to obstacles, suddenly the stakes are 10/10. Very easy to see how people roll so often. Unless you’re in a rock bouncer, if your line doesn’t go just as planned you aren’t making it. That definitely happened to us on more than a couple occasions. The JK on 42’s that was with us said that any time there is rain, the trail is completely different afterward. One day you’ll nail everything and think you have the baddest rig ever, and the next day you fail miserably on everything.
We ended up winching on Chewy, Rocker Knocker, the second half of axle hill, and Rockpile. Chewy and Rocker Knocker were both traction issues. Chewy was super dug out and we just kept spitting the rocks out when trying to climb. Rocker we got to the notch and had the slider on the rock to pivot, but just could not get traction to follow through. Axle hill we got to the first shelf then couldn’t steer. No amount of Austin Powers moves would work. And Rock pile was just preposterous. Then we broke a front axle while getting winched out.
Still a successful trail, even with the winching. The tuning by @GooseTuned made a HUGE difference. Two-footed driving and properly bumping was awesome. I drove the two hours out from the end of Pritchett and just put it into 2H, and wifey was pretty amazed at what could be accomplished simply with a locker, a bump, and RWD only. The two hour drive out really isn’t an exaggeration. It’s a jaunt. With the suspension changes though-lawdy could we fly. But then stop and wait at every turn to make certain others don’t get lost, as is customary.
I believe we have more footage on action camera. I’ll update when we find it.
Ford Bronco Taking on Pritchett Canyon in Moab, UT View recent photos
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_7859
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_8163
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_8174
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_7872
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_7862
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_7869
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_8165
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_8171
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_8152
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMG_7877
timhood
Tim
Several
Have you done Rusty Nail? The trusty Moab bible says it's the hardest and Pritchett is second, though I suppose it's nit-picking to order them. Just curious what you think between the two. Both are above my Bronco's pay grade and my desire to tackle. 💀
Either way, I think I've done the max I will do, as descriptions like "not for the faint of heart," "common breakage includes axles and driveshafts, "rollovers common," and "expect scratches" are not phrases I respond with "challenge accepted!" for the trails ranked more difficult than Top of the World. 😆
I'm impressed you considered it. Trailside repairs are not my idea of "just another day off-roading." 🙂 I can live vicariously through you. :wink:
BigFootie
Wisconsin
Bravo young man! Nice to see someone other than Rory do trail repairs on Pritchett!
swamp2
Push the build and follow up promptly by pushing the rig. Good on ya!
What is the plan for reducing the odds of another broken axle? Is there a good drop in option?
Also, only very loosely related (slightly OT):
I keep (slowly) eating my drive shaft slip joints. And I don't crawl anything like this... I started working with a well known axle shop, but they kind of just faded away through the (minor) development process. Who should I turn to and anything special I should ask for? TIA!
tobyw
Toby
Washington
2022 4-Door
It's a shame... Pritchett used to just be good clean fun. But it's been beaten to death by both Mother Nature and simple over-use. I ran it years ago in an XJ on 33's and only had to winch on Axle Hill. And it was wetter than... well it was wet :crackup:
Ford Bronco Taking on Pritchett Canyon in Moab, UT IMAG1229
SierraBronco
SierraBronco
Either way, I think I've done the max I will do, as descriptions like "not for the faint of heart," "common breakage includes axles and driveshafts, "rollovers common," and "expect scratches" are not phrases I respond with "challenge accepted!" for the trails between Top of the World and Rusty Nail. 😆
I think it’s this one and “Rear Steer” that are both pretty ridiculous. As in-the guy with the Rock Bouncer we were with sees them and thinks “holy shit.”
SierraBronco
SierraBronco
Classic XJ superiority. Could probably do it on snow without lockers.
SierraBronco
SierraBronco
Push the build and hollow up promptly by pushing the rig. Good on ya!
These are the Dana/Spicer UFDU 32 spline units, currently the beefiest you can get and drop in for the platform.
@BigMeatsBronco was working on a D60 setup but is now waiting further development until after dropping in the 5.2 predator. I do know that there is a suspension guy now working with an axle guy (both are working on our LT build) that are now in the process of developing a D60 or Ford 9” for the front. Stay tuned.
I really like Adam’s Driveshaft
SierraBronco
SierraBronco
Shit I’m not driving it. That’s all wifey. But I do in fact do the trail repairs 😉
Valhalla
Valhalla
Chattanooga Tn
Nice write up! thanks for the share, maybe one day I can get out to your side of the world to see how it stacks up!
