Ed Morris
Ed
Longmont, CO
Jeep Grand Cherokee
I just finished installing the @Lobo Off-Road HNT Hidden Winch Skid Plate and Openroad 13500 winch on my 2-door 2.3L Badlands with Capable steel bumper and 3-inch lift. Here's what it looks like:
Ford Bronco Lobo HNT Hidden Winch Skid Plate and Openroad 13500 winch installation, pictures, and review 20250719_115535_FrontView
(Note: I'm still weighing hook options. I've never owned a winch before, so I don't really know what I'm doing, but I like the idea of using soft shackles wherever possible, so I'm leaning toward foregoing the hook entirely and just installing a rubber stopper to keep the loop from going into the fairlead.)
I relocated the winch control pack here, fashioning a custom bracket to hold it in place:
Ford Bronco Lobo HNT Hidden Winch Skid Plate and Openroad 13500 winch installation, pictures, and review 20250719_115122_ControlPackRelocate
I also added a cutoff switch here, which I guess wasn't really necessary but I thought it would be nice to have:
Ford Bronco Lobo HNT Hidden Winch Skid Plate and Openroad 13500 winch installation, pictures, and review 20250719_115238_Cutoff
Finally, I fashioned a fork-like extension device to rotate my winch freespool clutch handle/lever here:
Ford Bronco Lobo HNT Hidden Winch Skid Plate and Openroad 13500 winch installation, pictures, and review 20250719_115209_Freespool
(Note: The fork-like part on the end of this rod allows me to turn the freespool handle even though there's a fairly significant angle between the rod and the handle axis. Fortunately, this handle is very easy to turn onthe Openroad winch model that I used. Most other winches I've seen have had a much stiffer freespool lever, which would have made for a bigger challenge.)
Review/Concerns:
I generally like the design and sturdiness of this skid plate system. I think it's probably the best option there is for adding a winch without extending your front bumper or sacrificing approach angle. However, I do have a few fairly major worries/concerns:
1) Maintenance is going to be extremely difficult with this system. Because the winch is mounted to the skid plate itself instead of to a bracket separate from the skip plate, you can't just drop the skid plate to gain access to the winch, or to the bottom front of the engine bay either for that matter, to reach the radiator hoses or whatever. You have to instead drop the whole skid plate and winch assembly as a unit, which is going to be much more difficult not only because of how heavy it is but also because it involves disconnecting all the winch wiring from the top and re-running the wires when you're done. I just hope I never have to replace my winch rope, or re-tighten the wire connections on the winch, etc., because this will be a major chore.
2) Although the skid plate itself is very thick and strong, I'm a little concerned about the ability of its attachment points to withstand a really hard winch pull. On the back, it's attached to the diff mount crossmember with two very hefty bolts on the driver side (so no concern there), but only with the one much smaller original skid plate bolt on the passenger side (so possibility for shear?). On the front, it's attached to the frame via the very sturdy new intercooler brackets with three M10 hex bolts on each side, but my worry is that these hex bolts don't screw directly into the brackets. Instead, they screw into some "U" clip nuts that you slide into position on the brackets. I don't know, maybe that ends up being strong enough, but I'm worried that these clip nuts could move with a hard winch pull, especially if that rear passenger side bolt were to shear.
3) I don't understand why there's an open slot directly above the fairlead in this skid plate (see pic below), but if you run over any thick brush, it seems like an opportunity for a stick to wedge up into that slot and potentially poke a hole in what I guess is the turbo intercooler. It's only the bottom of the intercooler that's exposed, not the front, but I'd still feel better if the skid plate protected it. Similarly, because this skid plate is so much narrower than the factory one, it's not protecting the wheel well areas and suspension components as much as the factory one did, although I don't see nearly as much danger in this.
Ford Bronco Lobo HNT Hidden Winch Skid Plate and Openroad 13500 winch installation, pictures, and review 20250719_115628_OpenSlot
Installation notes:
1) Installation took me (a retired guy without much experience in this sort of thing) almost a full 3 days. But most of that time was spent in designing and fashioning the custom brackets I used to relocate the winch control, add a cutoff switch, and access the winch freespool clutch, not in the actual installation of the skid plate itself.
2) The most difficult part of the actual skid plate installation was maneuvering the winch/skid assembly into place to bolt it up. There's a youtube video that shows this being done with a floor jack, but there was no way I was going to try to balance it on the tiny head of my cheap floor jack. I ended up wheeling it under the bronco on a stool instead, and then using a combination of lumber and bottle jacks to get it into position, but it was a lot of work. In retrospect, I think it probably would have been worthwhile to make some kind of custom wooden cradle for each side, ideally with stable jack points at each corner.
3) The other significant difficulty I experienced was in getting the front hex bolts to line up properly to screw into the "U" clip nuts on the new intercooler brackets. In retrospect, I should have dry-fitted the brackets to the skid plate before mounting them to the frame, to ensure that the "U" clips were all in the exact right position, ready to go.
B22-2023
Houston
Can’t say for sure but maybe Tri get air in there for the IC, which would not be a bad idea in that setup.
SierraBronco
Great write-up. Unfortunately there’s not a ton of great options to use a conventional winch on the front of the bronco without something like this or killing your approach angle putting it on the bumper. You can go competition and carry spare rope to get one to fit inside the frame rails, but it’s very spendy.
For hooks/fairleads you might consider this guy from yankum-especially with your location being so susceptible to hitting rocks. Delete the metal hook entirely, the rope is protected, and if you have a miswrap while using the winch it’s easy to wrap the rope around the fairlead to pull it out rather than hooking the rope to something.
https://yankum.com/products/winch-h...poxoGLTEZLG4sCms7TQCshdRSECRLXUsaAvHrEALw_wcB
Ed Morris
Ed Morris
Ed
Longmont, CO
Jeep Grand Cherokee
I don't think so. The slot is in the horizontal (i.e., overhang) part of the skid plate, with the intercooler sitting pretty much directly on top of it, so I don't see how it could be helping with the airflow.
Ed Morris
Ed Morris
Ed
Longmont, CO
Jeep Grand Cherokee
Yeah, that does look like a very cool option. Unfortunately, I don't think I can change the fairlead without dropping the whole skid plate/winch assembly (see my #1 concern in the OP), so probably not worth it for me at this point.
Gotchaa
Los Angeles
Tesla
@Lobo Off-Road can answer questions about the stability of the winch on the plate. He installed mine because I had a 2.7 and needed the Mishimoto high mount to fit it. So far I can say that approach angle when rock crawling you need to take into account the hook as it can get scratched up if you aren’t coming up at an angle and getting one wheel up first.
The other issue I found is if you have the factory skid plates, oil changes are a bit longer as the lobo winch skid plate is on there tight, and while you only need to loosen two bolts to get to the oil pan, getting the plate back under the lobo winch plate is very tight, so far two oil changes have taken me longer to get the OEM bash guard for the oil pan than the actual oil change and filter itself
Ford Bronco Lobo HNT Hidden Winch Skid Plate and Openroad 13500 winch installation, pictures, and review image
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
I'm not a fan of the mounting location. It exposes the winch to too much dirt, mud and water.
Squatch
There's a pretty good solution that came out recently, but you need a high-mount intercooler and specific type of winch. I have the RC hidden winch and it's been fine for ~20k miles and I love driving through deep puddles after a hard rain, mud, and dirt roads with rocks that hit everything underneath.
Definitely keep your Broncos away from dirt, mud, and water... :wink:
mcinfantry
Lee
Louisiana
Badlands 2 door
I’m in louisiana, all we have is mud, dirt and water. Mines been fine though. I also made a trip to Ouray and Moab it the location was good there too.
I guess there could be a flatter state with more mud, water and dirt. I hope i never move there or off-road there.
Steve_In_29
St Johns, Arizona
I have no issue with getting Bronco into dirt, mud, water and also snow., However I don't see the need to store my recovery equipment where it is constantly exposed to that. Possibly iced up or packed with mud when needed. Something that also doesn't do any favors to the winch rope. Don't care to have to submerge myself to access the hook,
Being placed so low it can have a hard time winching at an upward angle without simultaneously pulling the front of vehicle into the obstruction. Or having to run the line over the obstruction thus damaging it.
The inability to easily check on the condition of the winch and its components for a pre-run inspection is another downside.
B22-2023
Houston
The people with the winch so buried you can’t access/clean/service it, the others with them high up on a shelf sticking out front…..I’ve come to the conclusion that somewhere in the middle, with true frame reinforcement, is the way to go. I need to get that Yankum thing next to take my hook out of the equation on approaches.
Squatch
Yup, compromises everywhere but that solution thay requires a high-mount intercooler may be the best fit.
Probably shouldn't have bought a Wildtrak considering the position of the alternator which I'd be much more concerned about leaving me stranded.
Steve_In_29
St Johns, Arizona
Alternator is in same position on all models of Bronco equipped with the 2.7. The 2.3 has it in only a "slightly" higher location.
So if alternator location is a concern then buying a Bronco isn't an option.
TruckCamper
Peter
Kingman AZ
We have the Lobo on our 2dr. I'd recommend going with a wireless controller. Clutch can be reached from the side of the skid (no need for custom extension). We haven't had much need to drop the skid/winch since install. I have an LED winch light to install which will make spooling the rope easier. No reduction in approach angle. Seems like the best winch solution for the 2.3L.
I've come to like the Carli winch bumper a lot on our Raptor. So much that I've considered installing on the 2dr. It weighs the same as the factory modular bumper. Extremely high clearance and tucked in being a winch bumper. We did slightly tweak one of the bolt on bumper ends rock crawling. Factory camera allows spooling rope from inside the truck.
Ed Morris
Ed Morris
Ed
Longmont, CO
Jeep Grand Cherokee
That sounds like a good idea. Is it just something you mount in the engine bay to shine down on the winch, or what?
