GreyZ
Gulf South Louisiana
Turbo 350z, Bronco Badlands, Xterra
I recently installed my Wagner High Mount Intercooler in preparation for a winch and am extremely impressed with it. The fit and finish is excellent and I work with high end charge air coolers in industry. The fitment is spot on. The intercooler takes ALL of the available space and is much larger than the comparable Mishimoto unit while still providing for more clearance for the winch. Below is a rough draft write up of the install. I am working on the photos and a video of the install currently. Let me know what you guys think.
Step 1
  • Remove pop clip securing air duct into airbox. Then remove the air duct
  • Remove the 8x pop clips securing the radiator shroud cover and remove.
Step 2
  • Disconnect the grill plugs above the passenger headlight. One Fluid line and one video line for those equipped.
  • Remove the bolts securing the grill to the support structure.
  • Remove grill my starting at corners and pulling straight forward.
Step 3
  • Remove the front two fender flare twist clips and pull the leading edge of the fender flare away from the body.
  • Remove the undergrill front fascia by pulling the corners away from the fenders.
  • Unplug the front bumper plug under the driverside headlamp.
Step 4
  • Remove the front bumper (this varies slightly with each bumper)
  • Remove covers over the front bumper mount bolts
  • Remove front bumper bolts
  • Remove forward skidplate bolts
  • Loosen rear skidplate bolts
  • Remove front skidplate
Step 5
  • Remove Christmas tree plug and three bolts securing each headlight
  • Shift headlight outward and shove long #2 screwdriver into the pin lock on the inside edge of the headlight as shown.
  • Remove and unplug the headlight.
  • Repeat for the opposite side.
Step 6
  • Remove the bolts along the top and side of the grill shutter assembly
  • Unplug the upper and lower grill shutter assembly plugs at the lower driverside corner of the radiator.
  • Remove the radiator grill shutter assembly.
Step 7
  • Remove lower intercooler brackets.
  • Disconnect intercooler inlet and outlet piping from the intercooler.
  • Remove intercooler.
  • Using a wrench, remove the upper intercooler mounting bolts and bracket.
Step 8
  • Lift the ac condenser by prying gently on the upper mounts one at a time and lifting the condenser. It should rise up by 1.5”
  • Position the Wagner High Mount Intercooler by tucking the driverside port behind the frame horn and then while lifting the passenger side of the ac condenser and pushing it towards the radiator rock the passenger side of the intercooler into position.
  • Install the upper intercooler mounts to the intercooler.
  • Drop the ac condenser back into the mounts.
  • Position the intercooler 1/16”-1/8” away from the ac condenser.
  • Center mark the mount hole locations of the intercooler to drill the frame mounts.
  • Remove the intercooler by reversing the install procedure.
Step 9
  • (2.7 specific)Remove the two intercooler pipes that were connected to the intercooler from behind the radiator. One will be a quick disconnect and one will be a hose clamp.
  • Install the Wagner intercooler pipes. The driverside pipe will need the quick disconnect adapter installed before being installed onto the vehicle.
  • Drill the marked frame and radiator support locations with a 7/16 drill bit.
  • USE A RIVNUT INSTALL TOOL to install the 4 rivnuts
  • Install the four rubber isolators, two large ones on the bottom and two small ones on the top to the vehicle.
Step 10
  • Bolt the intercooler in place.
  • Install the intercooler pipes.
  • Drop the ac condenser back onto position.
  • Confirm that the intercooler (specifically the welds along the tanks) are not touching the ac condenser.
Step 11
  • Remove the grill shutters from the grill shutter assembly.
  • Remove the grill shutter motor from the drill shutter assembly.
  • Trim the grill shutter motor mount flush and the center lower grill shutter mounts.
  • Trim 2” in from each lower corner, entirely removing the soft rubber deflector. As shown.
  • Reinstall the grill shutter assembly and check to see if there is any additional trimming required.
  • If not, bolt grill shutter assembly in place.
  • Remove the center two bolts from the bumper (forward facing) and grind off the sharp ridge from the bolt head (1/16”)
  • Reinstall bolts to bumper
Step 12
  • Reinstall headlights
  • Reinstall lower grill facia
  • Reinstall grill
  • Reinstall bumper
  • Check clearance between intercooler and the two bumper bolts that were shaved down.
  • Check clearance between intercooler and ac condenser.
  • Reinstall radiator deflector panel and pop clips into place.
  • Reinstall intake scoop and pop clip into place.
Ford Bronco Wagner High Mount Intercooler Install Write-Up Bronco front mid install.
Ford Bronco Wagner High Mount Intercooler Install Write-Up Bronco front without bumper
Wickedbronco
Jon
Chicago
Thank you for the detailed write-up. I am curious to see your winch mount as I plan to do something very similar.
GreyZ
GreyZ
I have it in CAD, but it will be a .25" plate that mounts on the 4 skid plate mount bolts and ties into a plate that runs across the front bumper mount locations to mount the fairlead in the opening. Should have room to reach in and actuate the clutch.
I will have the contactors and relay remote mounted either down low or next to the battery depending on room.
I have a Warn 9.0RC winch going in. It is very narrow and will tuck between the charge pipes easily. There is only 21" between the charge pipes, so most full barrel winches will not fit.
Gene Dios
Atlanta
Do you mind posting a screenshot of your cad design? I've been thinking through a design that uses the space in the same way you're doing.
GreyZ
GreyZ
Need to finalize some of the bolt positions, but here are some images.
Ford Bronco Wagner High Mount Intercooler Install Write-Up winch1
Ford Bronco Wagner High Mount Intercooler Install Write-Up winch2
Ford Bronco Wagner High Mount Intercooler Install Write-Up winch3
Ford Bronco Wagner High Mount Intercooler Install Write-Up winch4
Tricky Mike
21 Bronco
What winch are you using for a model? It's pretty small, my Evo 10 fits tightly between the frame horn faces. I even had to mount it slightly off center to fit.
GreyZ
GreyZ
Warn 9.0RC. It just came in yesterday. It is very small for a 9k. its a narrow drum. <17" wide.
Wickedbronco
Jon
Chicago
I like the design a lot. Is it a single piece or two pieces welded together?
GreyZ
GreyZ
Planning to just be bolted together. Welding on that axis would not add much strength and would make it much more difficult to install/remove.
Running some structural analysis on just the mount plate, it is showing that it should have no issues from a loading standpoint but had a bit more deflection than I wanted. The second (front brace) piece is really just to help limit the deflection of the fairlead mount.
GreyZ
GreyZ
Finally got the last round of double checking my measurements and using some 3d printed templates to get the angles right.
Ordered the plates from sendcutsend and should have them towards the end of the week.
I also realized that the removal of the OEM intercooler leaves a pretty large opening for the radiator fans to pull air in and bypass the radiator. I am working on making a printed block off panel in ABS to cover that and improve the fan airflow through the cooling stack. Here is a few images because everyone likes images.
Ford Bronco Wagner High Mount Intercooler Install Write-Up winch assem B 12.30
GI_Jo_Nathan
Jonathan
Very cool! Good work!
Do you think running a support across the back would help/be necessary? Definitely a long flat piece of metal.
GreyZ
GreyZ
I completely agree. I did some stress simulations, and in worst case situations it is still well below yield, but there is a bit of deflection (.12") at a full 9000 lb pull. (This will hardly ever be the case.)
If It moves too much I will add a welded brace along the rear. I couldn't easily do a bend there due to the sendcutsend bending capabilities and I figured doing it and measuring it would be the best way to get a real idea of how it will flex.
GI_Jo_Nathan
Jonathan
Makes sense!
I was going to do mine with the RC 9.0 because there were a couple around for pretty good deals. I finally decided I'd rather set mine up for a full size winch to make it easier/cheaper to replace in the future. They are very proud of those RC 9.0's, so I really didn't want to have to buy a new one. 😂
