BroncoStorm
Storm
El Dorado Hills
2018 Jeep Grand Cherokee
I'll just leave this here, LINK to the full press release 👌. Very excited to run these. You may ask why these took so long, 4 years to be exact. It’s because a ton of R&D + tuning was done. The tech built into these is outstanding and very unique. These are position sensitive dampers and have 5 different valve zones based off where you are in the stroke.
Speaking from past experience of having 8112’s on my taco these will absolutely make bronco a different vehicle, entirely. Let’s party!
Spring rates: Front: 400lbs/in, Rear: 288lbs/in
Sasquatch package height adjustability (will be more if you don't have factory SAS:
Front: 0-1.4”, Rear 0.5-1.1”
Aftermarket upper control arms are not necessary. This kit is designed for 35's but you can run 37 if you limit travel or get aftermarket fenders.
UPDATE: I’m running these and they are absolutely sublime. It fills the gap between the regular Bronco and Braptor for me.
GI_Jo_Nathan
Jonathan
Well I didn't make it very far into that before I realized they are way out of my price range.. 😂
My man hope with these being released is that maybe the 6112s will come down in price just a little more.
BroncoStorm
BroncoStorm
Storm
El Dorado Hills
I hate saying it but you get what you pay for... If you've ever ridden in a vehicle with the 8112's you'll get it. They took a long time to come out with these and there's a reason for that. Can't wait to see a head to head with these compared to other systems.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
They are to late to market and doubt they are customizing these for each customer. Bilstein tends to not to offer much in the way of multiple options so I bet its going to be for 4 doors and stock weight.
GI_Jo_Nathan
Jonathan
I don't doubt that for sure. But for what I do with mine I definitely know what I can live with and without depending on the price.
MPTB
Pat
Wisconsin
Spare me the 40 min long video. How much do they cost?
GI_Jo_Nathan
Jonathan
No clue. I'm just going off of the few specifications they mentioned in the first 5 minutes.. 😂
2door
AA
2022 Bronco® The Sasquatch™ 2-door
akturbo
Seattle Eastside
'21 Bronco, '24 2D HLE (wife's), 3500HD Chevy, Rav4Prime, Turbo Skidoo
They do look like impressive shocks, seems the target use case is a Bronco on 35s without mods for a badass desert runner (but not addressing non-shock weak points)? Not sure I followed their all their logic on the cost benefits, at least they didn't apply to my '21 and how I use my Bronco.
2door
AA
I’ll keep my stock yellow shocks with pop off reservoirs a little longer.
They're saying that for achieving the same level of performance with the suspension components from other manufacturers, you would have to spend $15k+. Buying a Braptor would be another alternative.
If Santa doesn't receive my gift request, I'll probably go with the 6100's when the OEM Bilstein's wear out. Anyway, the 8112's would be an overkill for my 2 door. They look very sexy though.
