1.5" Wheel Spacers on Sasquatch?
threeonone
Canada
Jaguar
Yep, 1.5" from CJ Pony parts. So far, so good. Coming up on time to recheck the torque but they haven't loosened on any previous checks. With the 315's on the stock BL wheels it gives about 2" of poke from the stock flares... you will get very dirty
Edit just to say you won't have any issues fitting a 1" with factory studs., my factory studs sit flush with the spacer and those pockets on the back of the BL wheels look about .5" deep, eo you'll clear without any trimming.
Was taking a picture of my fogs here but you can see the poke with the tires/spacers
Do you have 315's on the stock non-sas wheels here? Or do you mean stock sasquatch wheels? I have the optional badlands 33's and I'm looking to put 35's on but I know I will need spacers to not have any rub.
iamchewby
Chewby
Non-sasquatch, beadlock capable badlands wheels.
Ford Bronco 1.5" Wheel Spacers on Sasquatch? 20220113_104631
This is before the spacers, without them there was only a very slight rub on the front of the UCA at full lock that you can see here so in all honesty the 1.5" is probably a little much... but it looks cool
Ford Bronco 1.5" Wheel Spacers on Sasquatch? 20220113_124957
PatioDaddio78
Kirkland, WA
Yukon XL
Is the pick of the bronco with the 1.5" spacer? I'm trying to decide about doing the same thing to mine. How much taller is it from stock? Looks real nice. :)
iamchewby
Chewby
Thanks! It has a 1" level on it, those pics are pre spacers. Here's a couple with the spacers on.
Ford Bronco 1.5" Wheel Spacers on Sasquatch? 20220203_162847
Ford Bronco 1.5" Wheel Spacers on Sasquatch? 20220129_162739
Ford Bronco 1.5" Wheel Spacers on Sasquatch? 20220203_200732
Frankie945
Frankie945
Frank
Louisville KY
Q50
Installed my Bora 1" spacers on my wife's BL with opt wheels. The spacers on the front were flush with the studs. On the rears, the studs pokes beyond the spacer 3/16"
Front
Rear
They still fit ok with oem wheels though right? Or did you need to trim. I figured they’d fit into the hollowed out spots in the wheels.
Lurker B6G
Murph
Cleveland, OH
Ford Explorer Timberline
Front
Rear
Thank you for the great information. It is always appreciated when people take the time to document reliable information. Again, thank you.
threeonone
Canada
Jaguar
Just to verify here, you have 315/70R17 KO2's on here right? Trying to get away with the same thing on my optional wheels. Thanks again.
threeonone
Canada
Jaguar
Front
Rear
Where did you order these from? Can't seem to find the 1".
Stripes136
North Florida
youtube.com
2022 Ford Bronco
Front
Rear
Hi BlueBronco - Do you happen to have a picture of the poke with the tires on and the 1 inch spacers installed?
BlueBronco
DFW
No but if you remind me later next week I can take a pic when I get back in country. They should only poke out one inch.
