0 Offset Wheels. Need Spacers?
ENassif
Eugene
West Des Moines, Iowa
Chevy Volt
Good news and bad news. Found these wheels for a steal of a deal. 6x5.5 off of a Silverado. Only issue is offset. 0 offset currently.
Could I pull these off? with spacers? Any recommendations?
These wheels are quite literally 1/3 of a new set which is why I don't want to pass it up.
TIA.
Bronc-itis
E
South Florida
Q50 (bronco soon)
Pics?
CarbonBronco
Tony
Socal
99 Toyota $runner
0 offest should work fine. adding a spacer will put that wheel in the negative offsets. so unless you are looking for more poke outside the flares then no need to add spacers.
Beachin 74
Delaware
At zero offset they will stick out past the fenders some. Spacers will make it worse.
CJ1064
Clifford
Monmouth County, NJ
GT350, Cherokee
What are you going to do about the 5th wheel ? Post pics once mounted
