Excessive paint wear on tailgate
jofer
Salt Lake City, UT (prev Houston, TX)
'21 Bronco Sport, '23 2dr Bronco Badlands+Sasquatc
Has anyone else had issues with significant paint wear on the tailgate where the seals contact? I haven't heard that many squeaks and rattles, but I'm noticing paint rubbed completely off in a lot of places (photos in a sec). I'm running stock size tires, albeit heavier than the OEM Goodyears. There's nothing else on the tailgate other than a table (which is pretty light).
Some of the scratches are on me (cargo/etc). But the rub patterns that exactly match where the seals contact seem suspicious....
I'm still under 30k (barely) and have an extended warranty regardless. Is this worth asking about?
Ford Bronco Excessive paint wear on tailgate PXL_20260509_212029444
Ford Bronco Excessive paint wear on tailgate PXL_20260509_212032338
Ford Bronco Excessive paint wear on tailgate PXL_20260509_212036210
Ford Bronco Excessive paint wear on tailgate PXL_20260509_212040257
Ford Bronco Excessive paint wear on tailgate PXL_20260509_212044644
Ducati1098
There’s a TSB for the paint wear on the top edge. It’s due to an accumulation of dirt between the rear window seal and tailgate.
jofer
jofer
Ah, thanks! That's super helpful to know!
Sir915
Shawn
El paso
2023 Bronco
I had this happen on my badlands. I just touched up the paint then added a clear xpel strip over the top lip of the tailgate to take the wear off the paint.
Mjasi3
Chicago
So does ford do anything about it as when I wipe the window rubber seal that touches the tailgate, it’s blueish from paint ruboff.
I’m surprised Ford is TSBing any of it since it’s just from dirt on seals
totaljustice
Kevin
Middle Sackvegas, NS
I touched it up with paint and got some adhesive rubber door edge molding and problem solved.
Bronco2022!!
california
had the same issue because of the rubber matt. Tuffskinz on Etsy made a custom protector for our Bronco, it’s nice has been holding up really well. If you contact them they will make it how you want. I didn’t like the Xpel, too thin and they only have it in clear.
Ford Bronco Excessive paint wear on tailgate IMG_3071
EgreenBadSquatch
Washington
2015 F-150, 2022 Badlands Sasquatch
What is the remedy for the TSB? I’m out of warranty and have an aftermarket hard top but have this issue.
Ducati1098
Basically just a strip of clear mylar tape on the top edge of the tailgate
Felix808
SRV CA
I was going to suggest stickers, but this looks better. Mine has been scrapped up from cargo, but not enough to bother me to start a sticker collection yet 🤠
23OBX2.7
AB Canada
2023 Bronco
Tesa or hockey stick tape lasts....
