Your Ideal Camera Placements? Share Your Thoughts
WolfBox
Florent
LA
2021 2dr Bronco
We all know that choosing the perfect spot to mount your dash cam can make a huge difference in the coverage and clarity it provides. Some of you swear by the traditional windshield mount, others find creative spots that work even better for their vehicles.
Now, we want to hear from YOU!
  • Where do you think is the ideal place for a cam if you can put it anywhere you like on your vihecle? And why?
  • Do you have unique placement tips, or lessons learned from trial and error?
  • What factors do you consider when mounting?
Your experiences and tips could help someone out in their dash cam journey. Plus, we may just feature some clever setups in our next post!
Can’t wait to hear what you’ve got to say. Let’s keep innovating together.
EvilJim1971
Jemison Al, 35085, USA
www.instagram.com
2023 Bronco Heritage Edition
I have my main camera replacing the rear view mirror.
The rear camera is mounted top canter of the rear window.
Since I don't have ACC, I mounted the front camera right to the empty ACC box.
Not fancy or innovative, but works well for my use case.
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
I like your spot 4… maybe more forward pointing rearward.
looking to place one in the front Ford HD bumper in the light pocket corner to have clear visibility forward @ tire (driver or passenger??). I wheel solo
@5GENIDN … need to comment on the thread and show your belly cam.
Wolfbox, hopefully will be able to purchase extra cameras to install and switch which one(s) are plugged in /needed at a given time.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
EDIT: They've apparently replaced the connector in question on my unit with a waterproof one, and they offered to send me a replacement rear cam with the waterproof connector since I started having connection issues! :)
I just want to throw it out there, the connectors between the camera and the wire harness really need to be made waterproof - I've unfortunately had a lot of connectivity issues with my rear camera either disconnecting or going into "reverse mode" while driving especially when it rains, despite loading dielectric grease into the connector and wrapping it with electrical tape and even trying heat shrink. Thinking about snipping off the connector and soldering in a replacement waterproof 5-pin connector. Just something to be mindful of when mounting your camera - make sure the connectors are waterproofed as best as you can. The included connector are this style:
I'm probably (just for the rear cam) going to solder in this style:
JimmyMac
Jimmy
I have yet to hook up my 3rd camera, but I want to install it under the body towards the rear facing forward. I also want to have an alternate 3rd camera for daily use for in-cab. I would only unplug that one and plug in the under body cam when I am offroad. Currently I'm using my Wolfbox as my primary mirror with the rear cam near the rear window. However, I might put it outside if I can find a decent location.
WolfBox
WolfBox
Florent
LA
2021 2dr Bronco
Thanks for your feedback. We have improved that connector.
Nibroc99
Corbin
Rochester, MA, USA
Glad to hear it! You guys have some of the best customer service that I've seen from a car tech company in a long time - just reached out via email and got a response right away about getting a replacement rear cam with the improved connectors. :)
HowieLong
WNY
How do you like the placement on the ACC box? Assuming you removed the cover of the ACC, is there a trick to removing it or does it just pull off? I have had enough plastic clips break on various pieces I get nervous about pulling things off.
EvilJim1971
www.instagram.com
I like it.
I actually just screwed it to the cover.
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
I like the main camera in the rear view mirror. That's the one for collecting evidence. I originally had the rear camera on the roll bar, which was great till I put my top on. Then I could not see more than two car lengths behind me. So I moved it to inside the spare tire. it works well there, but I would be happier if it didn't complicate mounting the spare. I have the front camera right under my winch hook. I think it's fairly well protected there, time will tell. I would mount it lower, (the lower the better.) but I don't think it would survive.
