Yakima Platform Rack Size?
Black_Stallion13
Cincinnati
Tacoma
I like the size of this rack Ford has on the accessories site: VM2DZ7855100C - it looks like it fits pretty perfectly over rear portion of the hardtop. I plan on running it the same way as the pic below with Mabett's new crossbars.
I assumed it was just the regular Yakima lock n load rack, but I'm wondering if maybe it's a custom size for Bronco. I believe the smallest lock n load Yakima sells is 55x49 which seems bigger than this one. Has anybody ordered this rack from Ford and can confirm actual dimensions? I don't see dimensions listed anywhere for it on Ford's site 🧐
Ford Bronco Yakima Platform Rack Size? Screenshot_20230503-205907
Hot Pepper Diamond
Justin
Knoxville, TN
Bronco Black Diamond 4 door
That listing is simply for the flat platform piece. It would be mounted to crossbars
Black_Stallion13
Black_Stallion13
Cincinnati
Tacoma
Yes. I'm asking if anybody knows what the actual size of the platform is since Ford doesn't list that info - they only refer to it as "small" on the product listing
Hot Pepper Diamond
Justin
Knoxville, TN
Oh sorry, I do think that’s the 55x49 size… I saw you typed rack and thought you meant the entire thing.
Could also be the 60x54
B_Wagon136
SoCal
Black Diamond Bronco
Those measurements just don't visually reconcile with the photo. I'm with the OP and have wondered the same thing so I'm bumping this.. Has anybody ordered this exact product and if so can you please confirm the rack's dimensions?
Hot Pepper Diamond
Justin
Knoxville, TN
Looked upt eh part number and found the size specs on a FOrd Dealer site... it is the original model I thought:
  • Dimensions: 55" long x 49" wide x 4" tall
https://www.rivercityfordparts.ca/oem-parts/ford-roof-rack-platform-small-by-yakima-vm2dz7855100c
https://www.rivercityfordparts.ca/o...f-rack-platform-small-by-yakima-vm2dz7855100c
Benzo
Ben
Bay Area CA
too many to list
I have the Yakima LockNLoad "K" platform which is the same as the Ford accessory item and it is the same as the one listed by ATLBronco75.
Here are a few pics with it on my 2 door.
Ford Bronco Yakima Platform Rack Size? 20220929_182818 (1)
Ford Bronco Yakima Platform Rack Size? 20220929_190042 (1)
Ford Bronco Yakima Platform Rack Size? 20220929_182826 (1)
Ford Bronco Yakima Platform Rack Size? 20220929_184442
Benzo
Ben
Bay Area CA
too many to list
Also if you buy the platform by itself, you will also need to purchase qty. 2, LockNLoad Crossbar Clamps for Roof Rack Systems. Each package has 2 mounting clamps and you will need 4. Amazon link for reference.
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
Did we ever figure out if Yakima has a small
Platform that fits just over top of the rear cap? I’m getting the trailrax half rack and want just a platform over the cap as shown in the concept photos.
Ford Bronco Yakima Platform Rack Size? IMG_4165
Ford Bronco Yakima Platform Rack Size? IMG_4166
alancorman1
Corman
Houston TX
2022 Ford Bronco
Can you post pics from above? I purchased one and wanted to see the positioning you used from above. Thank you
Benzo
Ben
Bay Area CA
too many to list
@alancorman1 Here you go. The first rail in the front lines up just behind the line of the hard top. I can take better close ups later if needed but this should help.
Ford Bronco Yakima Platform Rack Size? 20230709_122104
alancorman1
Corman
Houston TX
2022 Ford Bronco
That should do it. Thank you. I didn’t get an alert that you replied is the cause for the delay in responding.
alancorman1
Corman
Houston TX
2022 Ford Bronco
Facebook Marketplace size K with crossbar attachments for $425. Picked up on my way to Off Rodeo outside of Austin
Ford Bronco Yakima Platform Rack Size? IMG_2075
Ford Bronco Yakima Platform Rack Size? IMG_2085
