Wiring harness for fog lights ?
Steelhant
Chuck
Tundra
On the regular Bronco bumper they have fog lights and the modular bumper has none....just curious if there is still a harness or one could be added if I wanted to add fog lights ?
I know the up-fitter switches have contacts, is there is a different way ?
Thanks,
Chuck
Traveller
Todd
Jacksonville, FL
2022 Bronco
I have a Base, no lights, no wire harness for lights. Purchased Diode Dynamics fog lights and a wire harness. The harness will plug into the lights which connect to a relay and an adapter connection for back lights and fog lamps. I'll connect the adapter harness to the auxiliary switch wires at the firewall and terminate and should not have to use the power/ground from the relay to the battery. Harness also includes a switch if you don't have auxiliary switches.
MNBigfoot
MN
Thanks,
Chuck
If you have High/Lux(?), you probably have the harness there also, with the standard of Mid package you don't. Because they share the same harness as the camera and ACC(?), something like that..
Steelhant
Chuck
Tundra
Thanks for the response I will look !
Ducati1098
If you have front park aid sensors, the fog light connectors will be there even without factory fog lights.
If you have no factory fogs and no front park aid, then you have no connectors.
2 Tall Ones
Walter
Northern California
3 series BMW conv.
Nob here, but could use some help; can someone be more specific about where "there" is?
My OBX is equipped with the LUX pack and Mod front bumper.
@Ducati1098 when you say "fog light connectors will be there"; where is "there"? physically on the vehicle?
@MNBigfoot what have you seen? " you probably have the harness there "; again, is the physical location of "there" that I am asking.
Thanks in advance for your help and guidance.
Ducati1098
Ford Bronco Wiring harness for fog lights ? IMG_1845
Ford Bronco Wiring harness for fog lights ? IMG_1846
