Wiper control speed issues URGENT SAFETY
Lanshark
Little Rock, AR
Infiniti
Visual acuity and simple tolerance for what's on your windshield varies from person to person. So in the end, if it's enough moisture on your windshield to bother you then it is impairing your visibility.
Video aside, I assure you, when it happens in a heavy downpour to mine, there's no issue of perception, its virtually zero visibility. I can barely see the front of the hood. at highway speeds, in traffic. It can be scary as hell.
Snowdogyyz
23 Ford Bronco Wildtrak
Yep. Been there. Done that. It’s zero fun not being able to see and having to fiddle with a switch when you should be focused on the road and traffic around you. These are the dumbest smart wipers I’ve ever seen!
Jesse
Elkhart, IN
2020 Ford Edge SEL, 2013 Camaro 2SS
Hello! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this wiper concern. Thanks!
Sending a private message doesn't do any good. I sent a message and was given a case number and told I would hear from a "customer service specialist on the escalated suv support team" I have not been contacted by anyone.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
HEMI_Shaker
Maryland
2015 Dodge Challanger 392 Shaker (Sublime gree
My early 2023 black diamond i believe November build does this. It's a real pain in the ass. Starts fast then slows down to intermittent. Have to constantly turn the knob back and forth. If it is raining hard and I have it in the fastest setting it seems to stay going but slower speeds just turns into intermittent. And eventually almost nothing.
My 2023 Badlands behaves exactly like this. Build week was 5 December 2022.
I almost rear ended a car in heavy rain because the wipers set on high just stopped. So now when it’s raining I constantly tweak the wipers so they don’t slow or stop.
Fox island
F350 GT500’s FGT MACH I Z8
ScottyC
Rome NY
2022 Bronco 4 door
Are the replacement motors definitely not the same as the assembly line motor?
Well, since it corrected the issue for me, I would say unequivocally "yes"
Ducati1098
The wiper motor for the Bronco has never been updated or replaced. This will not solve any issue. It may temporarily, but it’ll eventually do the same thing.
2112
Fox island
many times the assembly line part will be different than the OTC part. Some times from different suppliers.
ScottyC
Rome NY
2022 Bronco 4 door
That is not correct - My system is now functioning properly.
Ducati1098
That’s not accurate at all. The wiper motor that it was built with, is the same as the service part sold over the counter at any Ford dealer currently. The share the exact same engineering and service part number.
Ducati1098
That is not correct - wiper motor part number is M2DZ-17508-C. Original motor p/n is M2DZ-17508-A.
Wrong.
Just because it is -C and not -A, doesn’t mean it’s been updated at all.
As you can see, M2DZ-17508-C has been the ONLY part number since 5/03/21 when the bronco was first built.
Ford Bronco Wiper control speed issues URGENT SAFETY 75AB2F36-F5E0-4946-BFB4-BF358A8BB2F9
2112
Fox island
I have been running (+ restoring) Fords my entire adult life (40+ years).
Just because they have the same engineering & part # absolutely does not mean they came from the same supplier.
Ducati1098
Anytime a part changes suppliers or anything else, the part number is changed.
Considering the part number for the wiper motor has NEVER changed, it’s the identical part that it was built with from the factory.
But, whatever. Not going to argue with you.
