Windshield Wiper Fluid Pump Issues
Tents+Tread
Thomas
Maryland
Ford Bronco - Toyota Tacoma
Seem to be having an issue with the washer fluid being dispensed, thought it was an issue with a line to the front nozzles but the rear window wiper also struggles to dispense more than an initial cough of fluid.. anyone else had a similar issue?
BigpoolBronco
Kerry
Maryland
Bronco sport
Hi, yes. My Outer Banks stopped pumping wiper fluid to both front and back wipers. Checked the fuses and all good. I’ll be calling tomorrow to set an appointment. I don’t hear the pump running at all when calling for fluid. I’m guessing the pump went bad.
Tents+Tread
Tents+Tread
Thomas
Maryland
They thought mine was leaking then just concluded “bad design”
very reassuring lmfao but all sorted now
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
I’ve had a few times where I have to hold the button down for anything to happen. I always have a spare washer fluid with me because it definitely likes to be full.
Moto26
Tucson AZ
Yep, it happens. We’ve had several instances where we thought we were out of fluid. Something wrong with the design, for sure… 🙁
RHeinz
Ric
Houston, TX
I think someone posted a video about a washer fluid hose becoming disconnected.
BigpoolBronco
Kerry
Maryland
Bronco sport
I can’t even hear the pump running when calling for fluid. Pump has to be bad I think.
Yeti II
Sam
Nashville, TN
2021 Ford Bronco Big Bend 4 door
Yep. Just happened to me. Fluid was nearly gone but no indicator telling me it was and zero fluid coming out of either front or rear. The wiper functions but no spray . Poop!
Yeti II
Sam
Nashville, TN
What did they discover? Bad pump? Bad fuse? I dont see any bad fuses so far. Have mine scheduled at the dealership this thursday for the same issue. No wiper fluid dispensing, it was almost empty and no indicator telling me so ?? Now its full and not leaking anywhere but zero coming out. Wipers work fine.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Mine just stopped working too…
kodiakisland
Arkansas
Mine stopped working for half a day on a 800mile day. Just decided not to work for 6 hours or so. It always has to pump a bit before there’s any spray if it’s been a day since use. My Tacoma can sit for a month and immediately spray as soon as it’s touched. Something’s not right with the Ford washer system.
redone17
Cold Spring, NY
There’s gotta be a way to test continuity, right? I don’t hear it even trying.
About to dig into the service manual.
redone17
Cold Spring, NY
Well, mine isn’t leaking. That’s for sure. It’s very much full.
What a pain in the ass to access. I’m all about doing the work myself, but in this case I’m taking it to the dealer to handle under warranty.
