Windshield washer not spraying
Brockdog12
NTX
2022 Explorer ST-Line
Mine would do this with a full bottle, it is pretty annoying.
ricstang
Richard
Lincoln, NE
1995 Ford Bronco
Mine just started doing this yesterday. My 21 VB Black Diamond goes like a snow mobile and the heater is awesome. Just need to figure our washer fluid issue
JTK37
New Jersey
2016 VW Golf R
Mine started having issues during the storm this past week.
I’ve had it since July ‘21 so it went through the last NJ winter. Friday I was out and about as the temps dropped from over 40F to the teens in the span of about 4hrs. The rear sprayer continued to work but the front stopped. It looked like the factory blue fluid had clogged the nozzles. 3days of temps under freezing and nothing I tried worked. I assume they were frozen…..but now the pump doesn’t run and the rear no longer works. I’m hoping it’s a blown fuse. I’ll have to check in the morning and update from there
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello, Joe! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this concern. Thanks!
JTK37
New Jersey
2016 VW Golf R
After swapping fuse #16 I’m good to go. I believe the factory fluid froze so the pump pulled too much current and blew the fuse. Warmer temps and refilled with a windshield washer fluid I’ve never had issues with and everything works as it should
Ground_zero298
Scs michigan
Mine blew the washer fuse sunday. Gonna add some meth to it this time round.
harleyrider67
Naperville
Jeep JKU
I live in Chicago and we had a blast of cold weather for the holiday weekend, and once I drove my 2021 Bronco Wildtrak the windshield solvent would not pump, the reservoir was full of extreme cold weather fluid. I ordered an instant on heater for the windshield fluid and installed it to fix the issue.
This is a safety issue, if this continues!
thanks,
mpeugeot
Not even labeled correctly in the manual and my fuze box doesn't have any labels.
mpeugeot
So strangely enough, my rear wiper continued to work even though fuse 16 was blown, so I thought I had a bad pump (not checking fuse 16 because Ford's manual says it is for the rear wiper motor). So I swapped the pump and No Bueno, still dead. My fuse also blew after the extreme cold snap in Texas... anyone seeing a theme here? It failed overnight, which makes no sense since the vehicle was not running.
Now access to swapping the pump was interesting, as I had no idea where exactly it was or how to access it. For those curious, you have to go through the passenger wheel well, remove some of the fender liner fasteners, reach in an pull really hard to dislodge the windshield washer pump (it took a while of wiggling and pulling to dislodge it). Pull it out through the fender liner and disconnect/reconnect the hoses, electrical connector, and then return it all to where it came.
So as I said, I didn't check the fuse until after replacing the pump, but it was blown, replaced the fuse and the pump motor runs again. Of note, the spray from the new pump is MUCH better than the original pump. I will have to see if it was a different part number, because the original pump sucked ass. The replacement pump I ordered was a Ford packaged and branded part for the Bronco which I purchased from Rock Auto.
Nolabel
Van
Mesa Az
Fuse 16 was blown as well on my Bronco but I noticed as well when my windshield was replaced the technician didn't hook up the water line back to the cowl. Everything works now after reconnecting the line and replacing fuse 16.
EilersPark
Hans
Leander, Tx
2012 Dodge Ram 1500 4x4
This happened on my 23 BD after the latest cold snap here in Texas. Not sure if washer fluid froze or was just low, but I did add quite a bit of washer fluid. Replaced fuse 16 and it fixed it.
Night Horse
Dan
Ooltewah / Cleveland, Tennessee
2022 Ford Bronco Badlands Sasquatch / Lux
I had the same problem- I found a solution! Blown fuse. Fuse #16 in the engine compartment fuse box. 10amp fuse.
Same here... the 10A fuse.
I noticed some mild arc marks on one fuse base and the fuse link itself was clearly blown. So, what ever caused it, the fuse did its job. Replaced the fuse and all is well again.
