Windshield Washer FUSE blown - Why?
SeldomSeen
Jay
Boulder, Colorado
google
One of our first real snow events here in Colorado Foothills Friday, and the washer, front and back ceased working. Didn't get a "low fluid" warning, but filled with half gallon anyway (so wasn't empty).
Since there was no pump sound, I assumed blown fuse. BIG ISSUE with no chart on underside of fuse box, had to spend 30 minutes on the ridiculous electronic owners manual search. That's so lame.
Anyway, discovered that front and back washer pumps are #16 under hood. Pulled it, was burnt out. Didn't see any "spare" 10 AMP fuses, so poached the sway bar disconnect, which my Wildtrac doesn't have.
So need to get a spare fuse kit, and now wonder, has anyone else experienced fuse blow with minor washer usage? Seems like a bug, as I sure wouldn't want to be on a long blizzard trip with no washer motor.
flip
Phil
IN
www.ruxerparts.com
Fords
Just going to put this out there but is it possible the fluid was frozen? It's not unheard of to see this happen from the factory or after it's been topped off especially if it doesn't have enough methanol or other anti freezing additive. Not saying this is what happened, just a theory.
Theories #2 & #3 are the motor is bad and caused the overload or possibly the wire between the relay and motor is shorting to ground.
SeldomSeen
SeldomSeen
Jay
Boulder, Colorado
google
Good theories. I don't think I have actually added any fluid since factory, so maybe they use cheap fluid that freezes? They are from Michigan (FORDs), I think, so would seem odd since that's a cold place in winter. Hope the 1/2 gallon I added will help if that the issue.
For #2 & 3, guess we'll see if it blow's again. Sounds like a warranty issue to me.
Anyone have thoughts on spare FUSES? Didn't seem to find any Ford specific fuses, so I guess I get the cheap Commie type from Autoparts.
Cousin Eddie
Jack
Pennsylvania
Cadillac
I think I have a similar issue. Washers worked last week, ran out of fluid. Refilled it , now no fluid comes out. There is no hum of the motor trying. I was looking for the fuse in the electronic manual I downloaded but there is no listing for the front motor, only the rear. I'll give fuse a replacement and see if that works.
I have to say, I have never in my life had to replace a fuse for a washer fluid motor.
Ford Bronco Windshield Washer FUSE blown - Why? 1671182494617
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
My fluid pump went. Going in for warranty replacement on Thursday. My fuses were fine, so I guess the pump is just crap. This is not the first instance I’ve read about this. Salty roads this week too. Guess I’ll carry around a spray bottle of wiper fluid. Haha.
But, 30 min? C’mon. Searched “fuse” and it took 5 - tops.
SeldomSeen
SeldomSeen
Jay
Boulder, Colorado
google
To clarify, whole time was approx 30 as i was trying to download to phone a HARD COPY as many times when I’d need it, I won’t have internet. I’m not that iphone savvy so all i could seem to do was save bookmark link to web based copy. Give me a fuse chart under the lid. Pretty basic.
redone17
Cold Spring, NY
@StickerFab makes a decal for the cover.
https://www.stickerfab.com/collecti...ies-underhood-fuse-box-lid-labels-2021-bronco
And one for under dash
https://www.stickerfab.com/collecti...r-understeering-wheel-fuses-label-2021-bronco
Bronqo
Andy
Tacoma
Same thing just happened to me. Drove from San Diego to Tahoe washer fluid worked fine. Next morning after freezing night temps, washer fluid wouldn’t work. Tried refilling reservoir, no luck. Checked fuse and it was blown.
Cousin Eddie
Jack
Pennsylvania
Cadillac
It ended up being a blown fuse. Apparently this isn't the only thread on the windshield washer having issues.
bjswifty
Brandon
CX5
Recently had this happen to me, only thing I can think of is the -10 degree weather we had where I drove into work and I'm guessing the fluid froze, as flip had suggested above. Sure enough, the fuse was blown when I decided to finally check it. I'm guessing I'll just replace the fluid with a better quality fluid that won't freeze, the scenario makes sense as to what happened.
thesocalexplorer
Southern California
Experienced this today also, was out in temperatures around 15*F overnight, and my fluid (summer blend) froze over. Attempted to spray my windshield and ended up blowing fuse #16. Replaced it & all is well now.
Area51BS
Ron
Badlands non SAS 4dr 2.3
That’s lame. How long have cars had wipers and fluid in very cold places?
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
+1 on the blown washer fluid pump fuse. Yes I did not have winter fluid and it likely froze (my water bottle froze and it was 17F at 4am). Not to mention my butt was FREEZING in my tent.
But I’ve had many cars and have forgotten to use winter fluid that freezes. But it never has killed the washer pump or the fuse. This is a very strange design and one likely to hit people when they need the washers to work. Of course they only work if the fluid thaws or you get the winter washer fluid. But dang blowing a fuse is odd.
The manual claims there’s a spare 10amp fuse (spot 21). But in reality it wasn’t there in my Bronco. Oh well. Off to get some spare fuses! For now I just used an upfitter switch fuse.
And thanks again @StickerFab for the fuse box label sticker. First mod I bought. Heh.
ncneil
Neil
2023 Bronco
This happened to my son's Bronco, too. We replaced it. We didn't have a spare fuse in the originally notated spot, but we took the 10 amp out of the uplifter switches (for now) and ordered some spares. Seems like a nuisance - we added some purple washer fluid. I wonder if there is a problem where a small spot is freezing and causing the overdraw.
majorhavok
Flagstaff, AZ
2023 Bronco
THANK YOU FOR THIS POST. I googled before and couldn't find any results for a fuse initially. I was traveling and stopped at a Ford dealer in Phoenix (Camelback Ford) and they said there was no fuse, it must be the pump motor and I would have to leave it for a day or two. Obviously that wouldn't work so I just ended up stopping every 50-60 miles to wash the bugs off at gas stations. I googled again today, found this post and sure enough a blown fuse in slot 16 in the engine bay fuse box. Swapped for a new one at autozone and washer fired right up. Now I will carry a few extras and an assortment I picked up.
Next will be engine bay and passenger fuse box decals. Ford really dropped the ball with that and no physical manual imo.
