Windshield replacement - what to look for
DaveInSA
Seguin, Texas
2025 F150 Lightning Flash
I did too - Rag and Ducati set me straight. But it's all computer now - just need some relatively straight roads with clean lines painted on them.
Well THAT could be a problem. 99.9999999999999% of the roads here are under construction or falling apart and poorly painted. Hmm..
I live in the mountains, and don't have a straight road for ... many miles, and yeah, paint isn't exactly pristine with lots of patchwork pot holes. It took a bit more than 10 minutes but it did finish the calibration for me eventually. I think FDRS, in the procedure, recommends a straight highway where you can just cruise for a bit - but the computer seems to be fairly forgiving on what it's actually looking for.
GroovyGeek
Boyan
'23 Bronco BD
Bugrad1990
St. Louis
1979 Bronco Ranger XLT, 2025 Badlands Sasquatch
It’s all ball bearings nowadays.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Make sure the new glass has the little Bronco graphics. That’s all I got…
ctskier
Joshua
Norwalk
2024 Bronco Badlands 7 Speed (June 2024)
Caught a rock chip on the freeway on the way home, next morning found a foot long crack. Insurance company is replacing it, I am paying a supplement for OEM parts so I will be getting new OEM window shield.
Anything in particular I have to pay attention to with the replacement? I have a 2023 BD, other than the wiper sensors I don't think there is anything that needs calibration.
just replaced mine in my 2024 Badlands and safelight did it no issues. They recalibrated too. I actually drove the car during that, as the tech couldn't drive stick
USAA paid for the entire thing, no deductible.
Onestepmore
Amos
Ballwin, MO
2023 Ford Bronco Badlands with Sasquatch
I just had mine replaced by Safelite Auto Glass about three weeks ago...sorry yours is cracked...They did a Great job and I thought it was going to be $495.00 and it said recalibrating is extra and I was thinking it would be inexpensive...well the calibration is another $495.00. I have a $1,000 deductible cos it was all out of pocket for me. I did tell him my wipers were new so he deducted that. Expect to pay close to $1,000 depending on your deductible. I would use them again the installer was Great!!!
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
Two things if you have ditch/pillar lights you have to remove them before they'll install the new windshield.
Just lifted a Tremor F150 with my buddy and when we had it aligned the tech told us there's a new law that will be going into effect soon that a calibration has to be done after any lift. Not sure that's true but I usually don't do a recalibration, and everything has worked fine on the 10 plus lifts I've done so that really sucks!
DaveInSA
Seguin, Texas
I ended up going with a local shop because of the price of safelite. I did NOT get OEM glass, so I don't have the bronco label any more.. But it only cost me $566 out the door.
Jwis
23 Bronco "WildLands", 52 F1, 66 Fairlane, 72 F250, 24 Lincoln Aviator
Had Safelite do my windshield, recalibration on the replacement Ford windshield was included--they installed at my home shop. I rode along with the tech who plugged a specialized tablet into the port. My area is hilly, and it did not calibrate as quickly as usual according to the tech. Once we got onto a level highway the tablet calibrated within a mile or so. Since then, I've had no issues with any of the systems. Interestingly, the ACC seems more consistent after recalibration. Previously I moved the ACC sensor to behind the grill...
jrollo7
James
NY
Range Rover Sport
@RagnarKon and @Ducati1098 answered this for me a while back, and I tried it out - yes, it's very easy in FDRS.
Basically fire up FDRS and start the procedure. Enter your fender heights. Leave the laptop running while you drive around for about 10 minutes. It has a progress bar, once it hits 100% you are done.
Sounds like what Safelite did for my other car.
GroovyGeek
Boyan
'23 Bronco BD
Fortunately in CA windshield repair/replacement is 100% covered by insurance without deductible.
GroovyGeek
Boyan
'23 Bronco BD
Really? Is that a blanket requirement? Mine are on DV8 brackets and ride off to the side, should not interfere with windshield removal but I may still pull them to be safe. Will not be at home when they do the work and my wife will not sign up for that job
Ford Bronco Windshield replacement - what to look for 1000007829
CMillBronco
Craig
You might be ok they don't look to be in the way, with mine I showed up for replacement and they sent me home to remove them.
Ford Bronco Windshield replacement - what to look for Bronco RCI rack
LT. DAN ICE CREAM!!!
Philadelphia, PA
2021 Badlands
I'm now on my 2nd replacement windshield from Safelite and I've never had to remove the ditch lights.
