Window reset weekly…
JB 208
JB
Minnesota
Big Bend Sasquatch
Is anybody else having to reset their windows weekly? I have to reset at least one of the four windows once or twice a week. Usually the drivers window, which makes sense as it is used most often. It’s a 22’ four door Big Bend. Thanks!
WheresMyBronco
Los Angeles
2023 Badlands
Happens to me pretty often too. I heard there's a window module update available at the dealership that might help with that a bit, but I don't know the exact details of it
NiceBronco
Canada
Check your door connections. I’d say the battery is done.
terp_ag@
Adam
Ashburn, VA
I have the same issue - now twice but on different windows. I got it fixed once at the dealer about a month ago but now warranty is over I am trying to reset my self.
The solution doesn't work for me becuase on step two when I roll up the window it just automatically goes back down on its own. So I can't just roll it up and hold the button for two seconds. I tried it several times. And I am certain its not a battery issue, the battery is fine.
Its very frustrating, to say the least. Any more suggestions?
thanks
ggjjr
George
Grosse Pointe, MI
A few, including a '25 Heritage 7sp
thanks
Any resolution to this?
jbob5059
Joel
Indianapolis
2025 Ford Bronco
thanks
Do it with the door open. This happened to me 2 days ago. Your window is trying to go too high and is getting blocked by the frame.
ggjjr
George
Grosse Pointe, MI
Mine has been doing this since new. I have always been able to reset it, until now. Door open, closed, etc. Nothing works. Any news on a fix?
VirginiaHeritage
Frank
‘25 Bronco HE
There is an override procedure in the manual for bounce back. Not sure if it only works once or disables the feature until a restart. If it lasts beyond the one time, it might allow you to get through the full reset process afterwards.
Ford Bronco Window reset weekly… IMG_3301
ggjjr
George
Grosse Pointe, MI
Thanks, I'll try it.
Techun
Pa
BD, 2.7, MIC, 4dr
My driver rear window is shitty. None of the other ones ever gets confused but that one does fairly often. I see nothing physical causing it.
