Window not going up
FordFamily4Fun
Kyle
Augusta, GA
'10 Escape, '16 Explorer, '22 Bronco 2-door
OK, 2022 BD. Bought used with just 10k on it. Have put only 700 miles on it over a couple of months. Window is not going up when door is closed. Yes, door is fully closed. Does not do that last 1/4 inch it is supposed to. Dash does not say door is open. Obvious from rattle and wind noise and looking outside vehicle. Yes, will be covered under warranty. Concerned about long term as I buy and hold for life of vehicle. Have not read much about this issue here. Hopefully some bad luck.....?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning, Kyle. Go ahead and send us a private message with your VIN and the name and location of your Ford dealer, and I’ll look into this concern regarding your window. Thanks!
RagnarKon
Ford Bronco, Escape, Focus
You have to reset the window limits.
  1. Turn the Bronco into accessory mode and roll the window down.
  2. Lift AND HOLD the window up switch as the window rolls up. Once completely closed, continue to hold the switch for 2-5 seconds.
  3. Push AND HOLD the window down switch as the window rolls down. Once completely down, continue to hold the switch for 2-5 seconds.
  4. Repeat step 2. While you are holding the switch up, the window may automatically shift up and down a bit while it finds the new limits.
Power cycle the Bronco and test.
TheKim
Kim
Haha - I've gotten pretty good at doing this just while driving.
Once in a while I'll notice that auto up or down doesn't work, and if you reset it, it works again.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
Why? You stop responding when it is a real problem...
omi205
BoJack
Austin
Im gonna get allot of flack for saying this. We spend $60k on a vehicle only to be riddled with funky windows. Random sounds. Cracking roof panels. Water leaks. Doors that close like they are made of cardboard. Different colored panels. Constant alarms going off (your hood has been opened). Etc.
This window issue is a common problem on the bronco unfortunately. It happened to me. I was able to correct it with the up/down hold for 10 seconds trick. It worked but im certain it will happen again. Good luck. The form is filled with issue posts. By any means the bronco is not for the “buy and forget” about it kinda vehicle. Its a “buy it and constantly monitor” for issues vehicle.
FordFamily4Fun
FordFamily4Fun
Kyle
Augusta, GA
Yeah. Obviously a pretty big concern. What I have found for now is each time I get into the Bronco I need to roll down the window a bit and roll it back up to fix the issue. Needless to say, this is not ideal. I'll get it to the dealer, but I have read people posting this concern even before it was a problem. It's one of those things as a long-term car holder if I would have bought the Bronco in the first place if I knew/thought of this being a concern. Love the Bronco in general, but some things will do that in.
omi205
BoJack
Austin
I love it too. Unfortunately its built like Chinese plastic.
Headsong
You'd think the Fordbot would know that.
Headsong
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
Hate to be too cynical with this but if you take it to the dealer, they are just going to do the relearning steps and say it’s fixed. I doubt they will decide that some component needs to be replaced. Have you tried the relearning steps @RagnarKon suggested yet? Let us know how that goes. I’ve had to do it maybe 3 times in the 3 years I’ve had it.
Rspayde
North Ga
2022 C/O Black Diamond
Y'all need to breathe. They are frameless windows it is pretty common that they need to be reset occasionally universally in cars that have them.
AZ_Liberty
2007 Expedition
Three Mustangs, 2001, 2006, 2008. All had frameless windows. None ever needed to be reset.
None of them ever had force sensors so touchy that I couldn't close them on a dirt road either.
1st 75th ranger
jeffrey
nj
you tube video ...worked on mine
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I had a '13 Mustang GT Premium that I bought brand new for just over $30K. It was leaps and bounds better than the Bronco I bought for over $60K a year ago. MyColor, V8, build quality, and I don't think I ever had to reset my frameless windows on it, maybe once or twice, but not every other month like I do the Bronco. And my rear windows don't like to index at all when it gets cold!
To The OP, I just had one of my rear windows stay indexed after shutting the door a week and a half ago. Drove all the way home from the ski slopes thinking I was hearing too much outside noise (driver's side). When I got home I opened and shut the door and it corrected itself. If that doesn't work, try the reset procedure mentioned. And fair warning - sometimes you have to do the reset several times in a row before it works ;)
