Window - Mirror interference?
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Something struck me as I was looking at Bronco pictures the other day....
How has Bronco solved the problem of opening doors (front doors specifically for the 4 door model) with window glass up/extended, not interfering with the body-mounted side mirrors? Looking at pictures, it looks like the door would not open very wide before the glass would impact the mirror. So I went and searched for some videos, but all I could find were videos of door opening with the window glass down, or the tube doors, or the doughnut doors. Has somebody seen this live or can surface a video to show how this works?
Philly
Dallas, TX
2022 JL Rubicon
The door should stop just short of coming in line with the mirror. Hopefully this prevents the glass from making contact. Maybe if you swung it open hard or some high winds catch it the glass might tap the edge of the mirror, but I would assume this is the first thing Ford had to work out when designing mirrors that stayed on the body.
Apples
Nick
2022 Jeep JLUR, 2024 Nissan Ariya
One of the walkthrough videos (don't remember which one now) showed the door stopping just short of the mirrors. It didn't look all that narrow in the video; wider than you'd be able to open the door in a parking lot.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
In the video that was a chat with the original designers, they talked about how much of a challenge it was to engineer the mirrors to work on the cowl like that. It sounded like an absolute headache, but I trust they must have figured it out.
BudgetBronco
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Ahhh got it. I figured it had to be either a mechanical stop, or a mechanism that automatically lowered the windows when the door was opened. The latter would seem a likely possible point of failure and broken glass, so good to hear it is the former.
kimmnen
Kim
Transit Connect & '22 Bronco Badlands
The door hinge has a stop/limit.
Ford Bronco Window - Mirror interference? SQ7A5788_LIx
LSU Jonno
Huntsville, AL
2022 Bronco
I think Doug's video specifically addressed this.
_2020_
Sylvain
MA
2014 Mini Countryman S , 2015 JKU, 2017 X5 3.5i
It doesn’t stop. The glass slams in to the mirror and shatters.
j/k
There will be a strap as accessory as on Heeps... ?
Seriously design of doors and mirrors looks promising!
Russtang
Russ
Chandler, AZ
03 Mustang Cobra
As John said above, Doug Demuro talked about it in his video.
BravoZulu
Alexandria, Virginia
2016 Nissan Murano
Has anyone seen anything addressing the door/mirror situation when the mirror is folded??
Apples
Nick
Unfold the mirror before you open the door?
Fuzion2Bronco
Asher
Base Sasquatch
j/k
That would have happened during the Design and Testing Phase?
Jfman
jean
Canada
Accord
Is it normal that the window gently touches the mirror on the passenger side when you open the door. Doesn’t do it on the driver side. Bronco is a week old.
