Wind Deflector on Stroppe wrapped Hood?
Ophthovet
Stroppe
Mario
Arkansas
2Door Bronco, BMW X6, Newell 45
Stroppe
Can anyone forsee any problems attaching a wind deflector to the wrapped hood of the stroppe edition? Just curious. Have one on the way and wondered if it would make any difference now with adhesion or in the future with removal.
PWillette
Parrie
Maine
Guessing the adhesion won't be affected but removal might not be good for the wrap. Usually a bit of gentle heat is required to remove from paint...good chance the wrap would lift along with the deflector.
Jugxre
Finland
Lamborghini Gallardo
I think you should be fine. The only potential concern is when removing it later, as the adhesive could pull up or damage the wrap. As long as the wrap is properly installed and the surface is clean, adhesion shouldn't be an issue.
Baja71
Stroppe
tw
Dallas, TX
1971 Stroppe Baja
Stroppe
I put one on mine.
lawber
AZ
2023 Raptor and 2020 Super Duty
I am going to wrap the entire car, what wind deflector did you go with, mind posting a link? The wrap on the hood is paper thin, def needs some protection
Scoop
Gary
Cuchara, Colorado
2026 Stroppe Edition, '74, '76, & '78 Broncos
Nope, not putting one on mine. Agree, removal is the issue.
I had one on my 22 Badlands. I did not find it very effective.
Ophthovet
Ophthovet
Stroppe
Mario
Arkansas
Stroppe
I ordered the one on the ford accessories page. Aeroskins II.
TheShark
I've had one on my wrapped hood, no issues but I see the point others have made about removal.
Ford Bronco Wind Deflector on Stroppe wrapped Hood? 470D9174-51B9-4BD7-B8D8-80AE134DB78C_1_105_c
Baja71
Stroppe
tw
Dallas, TX
1971 Stroppe Baja
Stroppe
I had one on my ‘23 Badlands and found it very effective. I have a lake property 1.5 hours away and the amount of bugs and pebbles I encounter hitting in my line of sight diminished significantly with the Aeroskins II. So much so I almost had one installed at Granger for the long back country highway drive home.
Scoop
Gary
Cuchara, Colorado
You must have had a better one than the one I had. In the 2 1/2 years I had the '22 I replaced the windshield twice. Maybe I'll notice a difference in bugs without the deflector this summer?? I still will not be putting one on the wrapped hood of my Stroppe.
