- Joined
- Jul 14, 2020
- Threads
- 125
- Messages
- 6,173
- Reaction score
- 7,131
- Location
- California
- Vehicle(s)
- Jeep Wrangler JKUR
- Your Bronco Model
- Wildtrak
- Thread starter
- #1
Just doing some preliminary research, and came across some conflicting information that I thought I'd run by the group.
And my specific case, my winch can pull up to 400 amps. When you look at wire gauge versus amp capacities, I would need a 4/0 wire.
With that said, there are online wire calculators where you can specify the length, voltage, and amps, and it will tell you the minimal gauge you need...they report back 2 Guage (and larger).
When I look up professional winch wiring kits, it seems most of them use 2 gauge.
And yet when I search for wire length and it's effect on amp handling, the web comes back stating that length has nothing to do with amps and only effects voltage drop. In other words if a wire is not designed to hold a certain amperage, making it shorter doesn't fix that.
Yet a 2 Guage wire is supposed to only be able to handle like 115 amps.
I mean I know there are people that have used smaller wire and it has "worked"... But there are also other people that have caught their vehicles on fire because the wire couldn't maintain the load.
Just wondering if anyone knows which is true. Either a short run of a thinner wire can SAFELY handle it or it can't.
Fyi... Once I get my bumper, winch, and solenoid all mounted up, I'm is going to measure and have custom cables made (They really aren't that expensive)
https://www.batterycablesusa.com/battery-cables
