Wildtrak vs Squached Badlands for Desert Running
530Squatch
Nicholas
NorCal
2002 HD Silverado Duramax Turbo Diesel
Going WT here and adding the armor. I flirt with the SBD of the BL all the time, and if that was the only difference I'd switch to BL in a heartbeat. What it comes down to for me is sport mode, cloth seats (I HATE leather and vinyl in the heat), and black>gray bumper with cyber orange.
So to me, why pay an extra ~$3000 for a sway bar and take 3 big hits? Im sure aftermarket will come out with a disco. Now of I end up a MY22 and go green instead of CO the BL is back in play if I throw on seat covers and get over sport mode.
Ford Bronco Wildtrak vs Squached Badlands for Desert Running Yarp
MrOzMan
Alex
If Ford had speced the Wildtrak with IRS, Fox suspension, and Torsen differentials, it could have been a true desert runner. It just doesn’t have any tangible benefit over the Badlands for doing what it says it was designed to do. I would get the Badlands 2.7 with Sasquatch, you don’t have to use the sway bar disconnect, but at least it’s there if you ever do want to try it out.
Canyonero02
2019 Ford F150, 2021 Jeep JKUR
are you sure Sport mode (f150) is 4 high? I don't think it is
That's on the previous gen Raptor. I watched a walkaround video of a new 2021 F150 and when it was put into Sport mode it automatically shifted to 4 high.
Silver-Bolt
Bill
Eureka, MT
Possibly 4A but not 4H. Sport mode is meant for the road, 4H is not. My Raptor going to Sport does not engage 4wd at all. Now you can engage both 4A or 4H while in Sport but it does not do it automatically.
linbackr99
Todd
Vermont
2017 Raptor Crew
Have been on Wildtrak since day one reservation - will be perfect for what I want in the Bronco. I think they are all sweet and you can not go wrong . . . but - for me - Badlands was never really even a consideration.
da_jokker
Jeep Wrangler JKUR
So with power being sent to the front and the back, but both being an open diff...why can't you use 4H?
I had fulltime 4x4 on my XJ so as long as the center transfer case allows for slippage between front and rear axles, 4H is totally doable.
Old Guy
Kevin
Vancouver, WA
Jeep JKU, Mustang
Get the Wildtrak. Or be like everyone else and get the Badlands, that has features you never described needing in your initial post.
Between the two I would get Wildtrak just not to be like everyone who says Badlands is the ultimate model.
Good luck on decision.
Silver-Bolt
Bill
Eureka, MT
4H locks the transfer case. You are fine in a straight line but don't try to turn on pavement. Your frontend will bind and you will break things. 4A the transfer case has a clutch pack that allows slip. No problem running on dry pavement. AWD and 4WD are completely different systems.
mpeugeot
Ya, I really don't get why the regular transfer case was even an option (other than just cost) because the advanced 4x4 transfer case is really the logical choice for the Bronco (with or without any locking differentials).
Although, I can understand why someone might feel that front and rear open differentials might be adequate for many people and use cases.
Personally, I certainly would have welcomed a torsen front differential, in addition to the locking rear differential with the advanced 4x4. That certainly would cover the needs of just about everyone short of the rock crawling crowd.
However, I think that it's overboard to offer the open, torsen, and front differentials as options. So I do understand Ford's strategy with regard to the drive train options other than the standard 4x4 and open differentials all the way around.
