Wildtrak Suspension Upgrade
bassam792
Bassam
Saudi Arabia
2024-2 Doors Bronco
Hey guys.
I do have my Wildtrak with HOSS 3.0 package included. I live in Middle East and usually go to Dunes on weekends.
The only concern that I have is mainly about the suspension system.
Does factory setup with HOSS 3.0 enough or should I upgrade the Tie rod, Billet Upper Control Arms, Rear Upper & Lower Links?
I just want to be extremely safe when it comes to jumping while off-roading as well increase the capability of the truck basically.
I'm okay with running 35s and current height is prefect for me. I wont go for 37s or lifting the vehicle at all.
I only consider developing the current setup if needed.
Links for what products do I need to add will help so much and I do care when it comes to quality.
PWillette
Parrie
Maine
Wildtrak is built for desert running out of the box...on 35s your good to go as is. If you decide to jump to 37s the other items you mention would need to be considered.
bassam792
bassam792
Bassam
Saudi Arabia
2024-2 Doors Bronco
thax for your advice. I did have some ideas about upgrading the shocks to 2.5 or 3.0 FOX Shocks but keeping the same SAS factory lift and 35s
