Where to tie into back up lights
Game Day 89
Buck
Bluedog89!
2023 Bronco
Hey everyone,
So I picked up a rigid backup light kit... I'm just wondering where everyone tied into the existing backup light wire at? Everything else was pretty straight forward but I wasn't sure if I could under the hood or back at the rear tail lights.
Thanks
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Depends on the connector those Rigid lights use. We only have harnesses that utilize 2-Pin WP connectors or 2-pin DT connectors (which the Rigids might).
It's a 2 piece harness
1) The pigtail, that plugs in-line with the factory circuit: https://www.4x4truckleds.com/crystalux-wp-2-pin-in-line-bronco-tail-light-harness-2021-ford-bronco/
2) The actual harness that connects the 2 lights to the pigtail (as well as an upfitter optionally if you want to control it from an upfitter as well as in reverse):
WP 2-PIN: https://www.4x4truckleds.com/crystalux-wp-2-pin-reverse-harness-w-upfitter-control/
DT 2-PIN: https://www.4x4truckleds.com/crystalux-dt-2-pin-reverse-harness-w-upfitter-control/
Game Day 89
Game Day 89
Buck
Bluedog89!
2023 Bronco
Looking at my box and parts... all rigid has is a wire that you would splice in with a regular crimp connector. Really don't feel like heat shrinking and cutting a new wire. That plug and play adapter with the pig tail I can buy and cut the end off and just hook up to my single wire should work.
Thank you guys for the help
Canyon Coolers
Jason
Flagstaff
canyoncoolers.com
2002 C5 Corvette, Dodge RAM 2500, Sprinter Van 2500
May I inquire which harness would work for a KC Flex Era 3 or Flex Era 1 ?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
dgorsett
colorado
F250, Mustang, Explorer
I'm going to revive ⁰this thread looking for expertise. I installed the RC Tubular Rear Bumper which came with a set of 60 watt, 5 Amp lights. I'm considering 3 wiring set ups.
1. Use the supplied switch and wire to a key on circut. Question: what is a good key on circut under hood and one under dash?
2. Wire to backup circut at taillight. Question: what color is backup wire at taillight? Will the factory wiring and fuse take the additional 5 amps?
3. Wire to trailer backup fuse ,58, under hood. Question: are add a fuse/taps available for a FMM type fuse?
Being lazy I'll probably do whichever is easiest, which is #2 if feasible. I have the Curt trailer wiring and can tap in to the Curt thru wire for backup, once I know the color.
Edit: the obvious answer to 2 is to use the tap linked here, but a couple things: I only need to tap one wire which u can do on the Curt thru wire. It's kinda crowded already behind the light with the Curt plugs. I don't understand how the linked pigtails can work with both LED and non as I believe wiring positions are different.
