Wheels and tires Question
Lawdawg55
Mcdonough
Hellcat Redeye
So for those smarter than I in this area (which is most) I have a question. I have a friend who bought a 2019 Raptor and within days jacked it up and put new wheels and 37” tires. Since then his stock wheels and 35” inch tires have been sitting in his garage. He told me if they will fit my bronco that I could have them for free.
anyone know if the bolt pattern is the same between the 2019 Raptor and the new bronco (mine is an outer banks if that changes anything)
I appreciate any info or feedback y’all may have!
Lawdawg55
Lawdawg55
Mcdonough
Hellcat Redeye
Ahhh I appreciate it. I figured it wouldn’t work. My luck isn’t that good to get new free wheels and tires! Haha
Cappy
Cappy
North Texas
2021 Ford Ranger
From what I’ve seen the Bronco is going to be a 6x139.7 which is actually the Chevy/Toyota lug spacing and I believe the F150 runs a 6x135. Sorry.
You’ve got good friends though!
@Administrator Okay, lock this thread, we've met our "wholesome" quota for day! 🤣
mC.242
2021 Big Bend 4dr (sold)
Lawdawg55
Lawdawg55
Mcdonough
Hellcat Redeye
I also don't know much at all about wheels and tires... but could you use his tires with a set of aftermarket wheels with the correct bolt pattern?
I was thinking that too. Or wondering if just the stock Outer Banks wheels could work with the 35” tires.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Depends what you mean by “work.”
Stock Bronco wheels are +55mm offset. Sas wheels with the 35” tires, are 315s, and are +30 offset.
If you put 315s on the stock wheels, they’ll interfere with the upper control arms (if not other things as well).
So, either different offset wheels (+30mm or less) or spacers if you feel comfortable and they’re legal where you are.
Here’s the tire / wheel specs:
Ford Bronco Wheels and tires Question 1617147633987
And here’s the thread with all the geometry figured out:
https://www.bronco6g.com/detailed-calculations-show-aftermarket-tire-size-fitments-on-bronco-trims/
Lawdawg55
Lawdawg55
Mcdonough
Hellcat Redeye
Thanks for all the info! That was extremely helpful! I appreciate you taking the time to respond with all that!
Beachin 74
Delaware
No go. The Raptor tires are 17" diameter wheels and the Outer Banks are 18" wheels.
Silver-Bolt
Eureka, MT
Tires, yes. Wheels, no.
Diydner
Ryan
Winter Springs, FL
Ram 1500
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I am going with an OuterBanks Bronco with the Sasquatch package but, I am not a fan of the wheels that come with it. i don’t want to have to buy new tires or anything else, just swap the wheels out. Will these fit? Will I have an issue with the offset?
SizeBP 1BP 2OffsetBoreLoadWeight
17x8.505x139.75x5.5-15110365045
https://www.visionwheel.com/wheel/7215/VisionOffRoad/398 Manx-Beadlock?finishID=1897
That offset is way out there. Might interfere while turning. Also, I can’t remember what the correct bore is (though spacers may be possible for that)
Seriously, everyone, we know +30mm are what Ford chose for 315 width tires. Stay close to that until we have real-world data.
If you just can’t help yourself, shop for current gen Ranger wheels with a 30mm (ish) offset. They’re the same.
Ford Bronco Wheels and tires Question 1618861718541
