Wheel help? I am going insane!
Cape Coral, FL
I have a new 2023 Iconic Silver Obx non SAS. I have decided on 17x9 wheels 1mm offset and 35x12.5 bfg ko2s. I like the blue shok, do you think it will look good? I would also add a blue stripe somewhere to match the wheels and a blue matched bronco script.
Ford Bronco Wheel help? I am going insane! 16851300495167784934659964682979
Ford Bronco Wheel help? I am going insane! 20230526_153050
Ford Bronco Wheel help? I am going insane! 20230418_151717
Lowcountry Bronco
William
South Carolina Lowcountry
Sure, I'm all for bold wheel colors! Worse case if you don't like it then you can powder coat in another color, sell them off, or use as trail wheels.
Sardine
2022 Elantra N - 6 speed & 2023 Badlands
Blue wheels are hard to pull off. I'm not sure if it really works on silver.
Silver-Bolt
Eureka, MT
Blue & silver work together. You need a blue accent on the paint. That said, I wouldn't do blue wheels. I would quickly grow tired of the look.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
1mm offset is going to be ridiculous amount of poke on non-sas. To each their own. I wouldn't go below 30mm.
76to22
OKC
2022 Ford Bronco
I've been thinking about the same look, but with a 2 door Squatch. I've got a good powder coat shop near me so if I do pull the plug I'll have a ton of different options to choose from. I haven't seen those fuel wheels in real life, but I think something just a little bit darker would look better.
ChrisB351
Shreveport, LA
Ive got -6 and to me its perfect poke
Ford Bronco Wheel help? I am going insane! tire
Brian’sBronco
OKC
23 Badlands/17 Range Rover Sport
I say do it, tired of black wheels that just blend in with the tire. I’m currently contemplating gold/bronze wheels for mine but wifey says it won’t look right because nothing else will be that color. 🤷🏼‍♂️
Bronc6g22
Jake
Washington
Depends on tire size and wheel width for sure. This is my setup with 315/70r17 & +30mm offset. Visually only 0.5" difference between the two.
Ford Bronco Wheel help? I am going insane! 20230429_114625
Kstiff
Joseph
Owensboro
I believe that is too much poke. You won't need to worry if it matches the silver. After the debris wears the paint off your vehicle you can paint it any color you want 😁
4Fords
Cory
Alabama
F250, OuterBanks, Bigbend, Ranger
I like bold. Not brave enough to do it though. I went with KnMC Carnage whel that is black with silver. Might look real good with iconic silver. 0mm offset. BFG KO2 33.6 11.5 wide. 21 lbs lighter than the 35’s. My wheel guy said 35’s too heavy for the tranny.
Ford Bronco Wheel help? I am going insane! 12E33F81-B96A-41D3-ADB5-040183B1C79C
Ford Bronco Wheel help? I am going insane! 4AC6ACB9-BEFE-44BB-A9A3-38B28597126A
