Wheel compatibility
ilkhan
Stuart
IA
None
Bronco uses a 6x139.7 lug pattern. What else would have that wheel pattern? Its a different pattern than the F-150. Does it match Jeeps? Something else from the Ford lineup?
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Ranger.
Also be mindful of the offsets. Ranger and Bronco have a +55 offset. Sasquatch wheels for the 35” tires are a +30
Gutter Clown
Explorer
Ranger.
Glad you posted. I read a little about offset earlier in the week to educate myself and would have thought the SAS had a negative offset, but boy was my logic wrong...
brocotect
ian
westport
jeep
does anyone know if the bore is the same?
EDIT:
nvm this I found my awnser
[ATTACH=full]95483[/ATTACH]
Incognito
Ford Bronco Wheel compatibility base
JoinedAug 19, 2020Messages990Reaction score2,224LocationPhoenixVehicle(s)2017 jk
Dec 11, 2020
67 - 87 Bronco II - 21 said:
It may, or may not be of any value to the Bronco, but the Ranger bore is 93.1 mm.
https://www.detroitwheelandtire.com...-10230-gloss-black-hol-10230-bbb-gloss-a.html
Mike L stated that the Base Bronco uses the steel Ranger rims.
That means a 93.1 mm hub bore.
  • Ford Bronco Wheel compatibility 1614955367596
Reactions:SuzH, JHawk and KH_59
Karl_in_Chicago
Karl
Chicago
Jeep has 5 lugs, not 6.
HoosierDaddy
__ Eric
Certain Toyota have the 6 x 5.5 bolt pattern also.
(Same as 6 x 139.7)
The offsets are the deal killer for most wheels.
Method and Black Rhino have a few 30 to 35 mm offset wheels..... I only look at 17".
Deleted member 19381
Guest
I can tell you that I will be ordering some Ranger steelies for some good winter/snow tires. Either General AltiMAX Arctics or Firestone Winterforce 2's.
smrpilot
PNW
'15 Silverado 3500HD, '68 FJ40
You can bet I'm gonna play around with my old blazer steelies from my 40 with 35's and try them on.
Ford Bronco Wheel compatibility fj40
grewhi
Greg
Seattle, WA
Maserati MC
(Same as 6 x 139.7)
Lexus GX460 - Rays makes a awesome set of wheels that will fit! I can swap my wheels
Ford Bronco Wheel compatibility 1614960906987
AcesandEights
Ace!
Oregon
DR650
Yeah, Toyota/Lexus uses the same pattern on their trucks and 4Runners. It's a very popular pattern, in my opinion.
JHawk
Ray
Heartland, USA
Fusion Sport
I think that the Toyota FJ, 4 Runner, & Tacoma share the same bolt pattern but the center bore is larger.
HoosierDaddy
__ Eric
Larger center bore SHOULDN'T be an issue.
The three sets of aftermarket wheels I've bought all used "centering rings" to shim them down to the proper bore diameter.
Raptor911
Raptor911
Broadlands, VA
Toyota trucks use 6x 5.5 but the bore is not the same as the Ranger/Bronco
(Same as 6 x 139.7)
Lakelife36
Ben
Interior of BC
I second that
Peter Gosenya
Gabe
Atlanta
[/QUOTE]
Please correct me if I’m wrong, why would a different offset matter? The methods that fit have a 4.5” backspacing versus the badlands wheel of 6.15 I think pushing the wheel out another 1.65“. Is that a problem other than potentially rubbing at full lock.
