- __ Eric
- Mar 6, 2016
- 38
- 6,453
- 16,814
- NW. Indiana
- 68&69 Broncos, 21 AMB Base 2dr 7mt
- Base
Really need to know what wheel AND tire width you are dealing with.Please correct me if I’m wrong, why would a different offset matter? The methods that fit have a 4.5” backspacing versus the badlands wheel of 6.15 I think pushing the wheel out another 1.65“. Is that a problem other than potentially rubbing at full lock.
Here is what I have for backspacing , per tiresize.com offset calculator. I strongly suggest playing around with their offset comparison app. With that visualization, you'll see tire width and offset will show you all you want to know.
16 x 7 = 55mm offset = 6.17" Backspace (Base)
17&18 x 7.5 = 55mm = 6.42" backspace (BB, BD & OBX)
17 x 8 = 55mm offset = 6.67" backspace (Badlands)
17 x 8.5 = 30mm off = 5.93" backspace (Squatch)
This is what an 8" wide wheel with 0 offset (4.5"bs) looks like compared to a Badlands 33 wheel and tire. Same tire in both models.
They are saying you will have 2.17" of extra poke per side. That's about .85 MORE than the Squatch, which already requires those wide-assed flares.
So, compared to Squatch, it isn't much, compared to standard Badlands, it's A lot.
With an 8.5" wheel, it grows to 2.4" more than the standard BL.
9" = 2.68"
What is Wheel Offset?
Wheel offset is the distance in millimeters from the center line of the wheel to the mounting surface. If the mounting surface is closer to the face of the wheel it is known to have a positive offset and if the mounting point is closer to the inside of the wheel it has a negative offset. Center or no offset is when the mounting point is directly on the centerline of the wheel.
What is Wheel Backspacing?
Wheel backspacing is the distance in inches from the mounting surface to the inside edge of the wheel. A wheel's width is from the mounting points of the tire beads, therefore the measured width of a wheel from outside edge to outside edge is about an inch wider than spec. An 8" wheel will measure 9" from side to side, this makes converting offset to backspacing not so straight forward. If an 8" wheel has a center offset the backspacing is not 4", it is actually 4.5".
