Whats the best tune?
Ninjak
Miami
The FP tune is very good. Yes, it does not have the highest PEAK numbers on the Dyno, the transmission gains are where it shines.
The whipple adjusts the transmission, but I do not know anyone with it. My Bronco is a daily driver, and it drives very smoothly. Shifts are wonderful, and switching modes matter. The sport mode is a different animal than the normal mode.
I hope to get to aDyno soon, I would like to see where I end up with my current mods. It should be interesting. I should be near Braptor power (RWHP), or maybe not. Lol But it will be worth doing just to see.
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
While on Fords FDRS the other day, I did some looking around. there's ZERO evidence ANYWHERE that there is a tune installed. in fact I suspect the average ford tech has NO way to tell if there is a tune installed. Most of the worry wart Karens have absolutely NO data to back some story ( or theory) about a warrantee company digging deep into a cars computer, just to find a tune , for the sole purpose of denying a claim. I'd love to read the story.
There are no red flags, no toggle switch to check for tune, no drop down menu with tune checker icon...NOTHING!
To do this, the tech would need to download and compare the PMI and configuration, and then check it against the MANY MANY other stock OEM strategies and configurations....just to find irregularities . but then would still have to prove they were detrimental in some way.
On the other hand, some fools have shown up for service, with there piggyback tuner still hooked up, right in plain sight. of course, then the tech can and will research the modification, IF there is warranty work that is DIRECTLY related to the tuner.
The thing you have to remember though is that because the Broncos use FDRS, they also send their configuration data to Ford on a regular basis. I believe its at least once a day with connected vehicle status turned on. So having a tune could theoretically send that information to Ford. With the FP box its not an issue because it allows you to keep your warranty
mksmwet1
Justin
Crystal mn 55427
2022 Ford Bronco Wildtrak
I have a 22 2.7 wildtrak. Here's the mods I've done so far and put it on a dyno. I got 366hp 432tq.. it MOVES!!
Burger Motorsports JB4 tuner
On a 93+/e85 fuel mix
Injen cold air intake kit
Injen hard charge pipe kit
Turbosmart VR19 blowoff valve
Next upgrades
Intercooler
Down pipes
DP Back exhaust
Custom dyno tune on JB4 with custom fuel mixture..
