What's Ford's logic regarding "Advanced 4x4" availability?
Big Boss
Outer Heaven
Bronco Big Bend
What is Ford hoping to accomplish by limiting the entry point for the Advanced 4x4 option to Black Diamond trim (for non-Squatch)?
To get you to move up to a higher model. I don't see why this is such a hard concept for some people to grasp.
Ford does not want to sell the base model, they don't want people to buy the base model. That is why the base model is so limited on options. It's the perfect blank canvas for people that just want an offroad rig, & those customers will probably make up less than 10% of overall bronco customers. The base model bronco exists so that it can hit the headline of starting at 28K.
Laminar
Iowa
Cougar
For a street-tire Base model, you would think the "Advanced 4x4" transfer case, with 4A (AWD), would be a legit selling point.
You say "selling point," Ford sees "upselling point." Ford keeps 4A away from the poverty-spec F150s as well. You have to get a Lariat or higher to get it on the F150.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
It is interesting that a large portion of buyers probably benefit from the “advanced” transfer case more than many of the other options , but neither they nor many of the salespeople they talk to will understand what it is and why they need it. Why it’s not on the base seems obvious to me, but I am old and have been around cars a long time?
vrtical
Doug AI
GSMNP, TN
Fords
poverty? I guess 45k is compared to the 70k versions :rolleyes:
Laminar
Iowa
Cougar
I'm not sure what you mean. You have to spend $51k to get 4A on an F150 where the base models start at $29k.
atonge40
Adam
Detroit, MI
2019 Ford Ranger XLT
Base is for two different buyers, neither of whom is a soccer mom.
One base buyer is scraping together pennies to get into a vehicle they probably can't afford, the other is someone who is going to strip it and put tens of thousands of dollars into customizing, aftermarket parts and Monster Energy decals.
Their names are Hank and Kyle. Both good dudes.
Or it's just for someone that wants a Bronco and doesn't want to pay a bunch of money for things they will never use. Since I want a manual transmission, I can't get the Mid Package on anything under the Badlands. That means I have to spend $45,000 just to get a manual + mid package. I'm not putting $10,000 or $15,000 into my Bronco. I just want to enjoy life in a two door vehicle with some off road capability. That means Base for me.
Plus, I doubt the Base + manual will have much depreciation. 2-Door Wrangler Sports hold their value well.
Techun
Pa
BD, 2.7, MIC, 4dr
Your example of "turning" illustrates my point exactly regarding street driving during rain and other "borderline" slick conditions. For the "clueless", 4A would be a set-and-forget option to use all-wheel drive without constantly having to remember to pop it back into 2H to avoid binding.
How's 4a going to help you turn?
KH_59
KH_59
Kevin
pearland tx 77584
F-150
I believe it has a center differential, allowing different wheel rotation rates front to rear. If you had ever made a tight turn on dry pavement in a 4WD without a center differential, you would know......
Toccoa
Isuzu Rodeo Sport
So that you’ll move up to at least a Black Diamond. Same reason you can’t get Mid package on BB with a stick, but you can on Badlands.
Laminar
Iowa
Cougar
The standard transfer case utilizes a computer-controlled clutch to let it "Shift on the Fly" and engage the front wheels while the truck is already moving. The 4A transfer case just has a heavier duty clutch that lets it modulate power to the front wheels as needed. The end effect is the same as having a center differential.
wvmtneer
‘Merica
F-150
I’m not either of those buyers. I want a base 4dr 2.7 Sasquatch as a 3rd vehicle and will throw some money at it for accessories.
lobbs611
Kyle
Independence, MO
2D JL Rubicon
A Kyle here. I resemble that remark. Tho I'm getting a Badlands.
Ford Bronco What's Ford's logic regarding "Advanced 4x4" availability? IMG_20201211_124450
TRACKTOY
ANDRÉ
ST-AUGUSTIN-DE-DESMAURES Qc. CANADA
F150 LARIAT CREW C. 3.5L ÉCO 2022+ BRONCO BL.2023
I have a mid level F150 XLT that only has 4H, need to go to Lariat to get 4A
HI
It's true about 10,000.00$ for a LARIAT. FORDd sell a price on base model not a BRONCO. it's a choice for a buyer to pay less for less or more for more , that's the way for all manufacturer ford, GM, Toyota ........
TRACKTOY
