What width 35s?
Diller
Russ
89 F250, 2012 Fiesta
I'm running 35x12.5-17 Trail Grapplers on SAS wheels with zero issues.
Ford Bronco What width 35s? 20241227_112802
Ford Bronco What width 35s? 20241227_145308
CrystalRedTintCoat
BertJ
Bay Area
‘22 Bronco Wildtrak; ‘13 Camaro 1LE
It looks like you got some natural poke with the 35s, is that true?
Diller
Russ
bassist
Northern VA
2024 Bronco Badlands w/Sasquatch Package
Don't get me started on 315/70R17 not being 35's... :crackup:
Manufacturer specs are never anywhere even close to advertised when the tries are mounted and under load.
After the tires are mounted and under load a 315/70R17 will be about 33 1/4" and 35x11.5R17 comes in at about 34 1/4". Yes there will be minor differences across brands but a 315 is nowhere near even close to a 35" IMO..
Photos:
315/70R17
35x11.5R17
But does it really matter?
2x4s are not 2” by 4”.
Your pants waist size isn’t really what your waist size is.
TVs don’t measure exactly as advertised.
bassist
Northern VA
If people and companies would stop falsely referring to 315's as 35's then no it would not matter... :crackup:
But if everyone calls them 35s, why the hell does it actually matter?
There’s nothing magical about 35”, and nobody is out measuring obstacles and doing engineering on a trail.
As long as a “35” is larger than a “33” and smaller than a “37”, and there are no fitment issues, then it doesn’t make any difference whether a “35” is 34 or 36.
raqball
Kris
WA
2023 Ford Bronco Badlands 2DR
Why are you so upset that 315's are not 35's? A bit odd but hey, you do you.. 🤣😂
bassist
Northern VA
35s aren’t 35” either.
BFG KO2 315s are 34.4” in diameter.
BFGs 35x12.5 are 34.5” in diameter.
But hey, fight the good fight for 0.1”.
MNBigfoot
MN
To run 12's in the quarter mile, you have to be quicker that 12.5 seconds and slower than 11.5.
raqball
Kris
WA
Yawn.........
And it's not 0.1" it's a full inch or more which might be important to some...
I honestly do not get why you are so triggered by me pointing out that 315's are not 35's.. Like I said, it's odd but you do you..
bassist
Northern VA
Yawn.........
Can’t you read? I literally posted the specs for both. 0.1” difference.
Actually, you must be able to read because you selectively edited the quote.
raqball
Kris
WA
Manufacture specs are mealiness.. I posted actual photos with a tape measure..
Just because a manufacturer tells you that a 315 is a 35 and they list specs does not make it true..
Now you are just being obtuse.. To the ignore list..
bassist
Northern VA
Just because a manufacturer tells you a 35 is a 35 doesn’t make it true.
Also, it’s impressive to see someone get so triggered by actual published data that they not only try to edit the quote to obscure that but put someone on ignore.
raqball
Kris
WA
I think tire width is preference. Some say pizza cutters are better for wheeling. I would assume a 12.5 floats better in soft terrain.
The age old wide -vs- pizza cutters debate..
This guy does a very in-depth comparison.
